bobndot
NY
cleary wrote: After seeing all the decks you folks have built over the years I just had to do it. Here's the result.
Well it's about time. Looks good .
Matthew_B
The boonies near Dallas, Oregon
Nice!
Good choice in beer too
cleary
Fairbanks, Alaska
djc486 wrote: What kind of nut did you use to attach the chain to the jack bolt?
Hey djc,
Look at the pictures again, I have replaced the pic showing the attachment with one that shows it much better. As you can see I used flat stock the same thickness as the original washer to attach to. I wouldn't use anything thicker as there isn't a thread to spare on the jack bolt. I'm going to replace the one in the picture with a wider, not thicker one for increased strength.
Chuck
2006 F-350, 4X4, Crew Cab, V-10, Torqshift, Dually. 2008 Okanagan 106UDB. Both 4-wheelers and snowmobiles. KL7AY Our website
RichP
North Franklin, CT
cleary wrote: . Any thoughts or suggestions?
Chuck
Just one. Lose that snake p**S your right hand and get a good beer.
Great job.
Rich P
RichP
1998 Dodge Ram 2500 CTD Standard Cab, Long Bed,
1989 8' Palomino popup TC
Life member NRA
djc486
Thanks for the new picture and the info.
cleary
Fairbanks, Alaska
RichP wrote: cleary wrote: . Any thoughts or suggestions?
Chuck
Great job.
Rich P
Hey Rich P,
How about one of these, home grown.
Chuck
ticki2
NH
Good job , simple and functional.I especially like the backround of the shop. Sometime I feel guilty when all that is left is a foot path through the STUFF , LOL
'68 Avion C-11
'02 GMC DRW D/A
Capt Eddie
usa
When you cut the square rails they are going to effect the support of the deck. I would run metal side to side.
DonCurley
La Sal, Utah
I must say, that's one fine looking deck there. Reminds me of something ... http://www.youtube.com/watch?v=nz82fjXqFQ4
-'07 Dodge 3500/QC/SB/SRW/4x4/6.7L CTD/6-spd auto/35" Toyo MT's/Ride-Rite air bags/RS9000XL shocks
-'07 Apex 8 fully optioned w/220W solar/2 T-145's/2KW Prosine/Honda EU2000i/Tundra fridge/AC/etc
-'00 Jeep Wrangler TJ 4x4, highly modified w/5.9L Magnum V8
cleary
Fairbanks, Alaska
Capt Eddie wrote: When you cut the square rails they are going to effect the support of the deck. I would run metal side to side.
Good question Capt. Eddie,
I've done a couple of mods to it. While I haven't cut the square tubes I have moved the chains, now cables, to the outside corners for more stability. I have also added adjustable legs so I can unhook the cables to access it from the ends which I have to do when it is parked in my garage.
Chuck
