RV.Net Open Roads Forum: Onan 4000w Generator Won't Start - Help Please!
 > Onan 4000w Generator Won't Start - Help Please!
ksg5000
Oregon
Posted: 03/11/12 05:25am Link  |  Print  |  Notify Moderator
Can you start the rig or has that battery died? No start issues described after rig has been sitting are typically low battery/bad ground related. Usually starting the rig (which combines the chassis/coach batteries) is sufficient to kick start the generator. Cleaning all the contacts on your battery may also be in order. Also - you might remove the harness to the control board and clean the contacts.
Kevin
artjacobs
Deep in the heart of Texas
Posted: 04/02/12 11:02pm Link  |  Print  |  Notify Moderator
You could also have a bad spot on the starter solenoid. You hear the click of the solenoid,still reading 12V. means no current to starter,or thru starter
Jpjlauer
ELKHART, IN
Posted: 04/03/12 06:07am Link  |  Print  |  Notify Moderator
Thanks ksg5000 and artjacobs.
But this issue was resolved and results posted last May.
Jim Lauer
Jim Lauer
2006 BTCruiser
2007 CRV tow
