RV.Net Open Roads Forum: Pinhole leak in pex piping...how do I patch it?
 > Pinhole leak in pex piping...how do I patch it?
LoudRam
Williamstown, NJ
Posted: 05/19/11 04:29pm Link  |  Print  |  Notify Moderator
As the title says I have a pinhole leak in my water line going to my toilet. It's about an inch or two belew the floor so I can reach it by pulling excess pipe up. How can I patch that? I bought some JB Weld "Kwik Plastic" putty but it says that it won't stick to polyethylene. Any suggestions?
Todd
Desert Storm Vet (US Navy)
2008 Forest River Salem LE 29FLSS
2001 Dodge Ram 1500 Quad Cab 4X4 w/360 (not stock)
Predator DX2 brake controller
Equalizer Hitch
If you can read this thank a teacher
If you can read this in english thank a vet
BillArf
NY and Florida
Posted: 05/19/11 04:38pm Link  |  Print  |  Notify Moderator
Self bonding silicone tape. There are various brands. Do a Google search for info. Marine stores for one sell it.. "Marine silicone tape"
You can also cut the pipe at the leak and then rejoin with a pex fitting. This is easy to do and preferred repair.
LarryJM
NoVa
Posted: 05/19/11 04:56pm Link  |  Print  |  Notify Moderator
Rick From Sequim wrote:
I'd try a hose clamp over a piece of tubber, like a tire patch or a piece of tube. Slip the rubber over the hole and tighten the hose clamp over the rubber. Works like a charm on pvc as well, no tools required except a screw driver.
That is what I would use if you can get the hose clamp (use all S/S and note some have just a S/S band and regular screw so use an all S/S) back down thru the hole in the floor. For the rubber you could also use some of the clear vinyl tubing split since it's on the cold water side.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
hershey
Albuquerque,(fulltime) NM, USA
Posted: 05/19/11 05:02pm Link  |  Print  |  Notify Moderator
There is a tape available at Lowes that is a fix-all tape. It stretches around the pipe or hose with a hole and bonds to itself. That and a hose clamp to help you sleep better [emoticon] might work unless you have enough room to use a splice made for that job.
hershey - albuquerque, nm
Someday Finally Got Here
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
SooperDaddy
Posted: 05/19/11 04:39pm Link  |  Print  |  Notify Moderator
PEX Repair
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. ">
Rick From Sequim
Sequim, WA
Posted: 05/19/11 04:48pm Link  |  Print  |  Notify Moderator
Rick ">
& wife Loie & Kodi Dog (blk male std poodle)
2011 GMC Sierra & 2005 25' Bigfoot RQ
LoudRam
Williamstown, NJ
Posted: 05/19/11 05:05pm Link  |  Print  |  Notify Moderator
Those are all some great ideas. Thanks. I like having a lot of options.
BillArf
NY and Florida
Posted: 05/19/11 05:10pm Link  |  Print  |  Notify Moderator
Self bonding silicone tape. There are various brands. Can be had at Lowes as you mention.
No need for a hose clamp if you use this tape.
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 05/19/11 05:12pm Link  |  Print  |  Notify Moderator
fordsooperdooty wrote:
PEX Repair
Ditto:
Get an inline splice for $6 at an rv or plumbing outlet and be done with it. There can be a lot of pressure in that line and chasing a leak will drive you crazy. The inline splices have worked very well for me. If you can put the ends of the hose in hot water they are easier to get on.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
LoudRam
Williamstown, NJ
Posted: 05/19/11 05:21pm Link  |  Print  |  Notify Moderator
Home Depot has that silicone tape too. I think I'm going to try that. It says it gives a permanent watertight seal. I rather not have a splice under the floor. That will be a last resort. Thanks again everyone. As usual you guys are a huge help.
