HAYWIRE
WEST PLAINS,MO.
Looking for a listing of which fifth wheels use hung wall construction as opposed to the laminated method.I know Crossroads and Cedar Creeks are this type,which others?
mwebber78
New England
Carriage uses hung walls. On Crossroads it's the 5th wheels that use hung walls, they have moved to laminated walls on the travel trailers.
2013 Jayco Eagle 334RBTS
Disclaimer for the daft: Don't confuse my opinion with facts.
fordsooperdooty
Newmar 5ers are also hung wall construction (also refered to as "built up walls"). If you are worried about de-lamination issues...Forest River says that Vacuum Pressure Laminated wall construction is 10 times less likely to have delamination than "laminated pinch rollered and glued walls". Around 75% are pinch rollered, the rest are vacuum laminated or hung walled (which are not prone to delamination issues).
Some Forest River and Thor products are vacuum laminated, and all StarCraft, Jayco's, Evergreen and Ever-Lites!
HamsHog
Fulltimer/ Palm Springs, CA
Hey Haywire,
Carriage uses hung wall construction also.
Regards, Hamshog
2009 Silverado 2500HD EC/SB Dmax/Alli - SuperGlide 18K - Firestone Bags - 265/75R16's -
2010 Carri-Lite 36XTRM5 w/ Big Foot - Champion 4000W
2005 Harley-Davidson Road King Classic
2005 Jeep Wrangler Unlimited LJ
2007 Fleetwood Pegasus Ultralite M-180FQ
SanMarMor
West Central Ohio
If I understand what Hung Walls are, Sabre has that construction. See the image below.
Mark
2007 Silverado 3500HD Crew Duramax Dually 4x4 w/ Curt Q5 20K Hitch
2011 Sabre 31RETS-6 w/ TrailAir Air Pin
http://camping.morrises.com/
soos
me
Mobile Suite is also a hung wall. HitchHiker is a vacuum wall.
Sue
soos-ontheroad.blogspot.com
Fulltiming since 2009
2012 Mobile Suites 36 TKSB4 pulled by a
2011 Ford F450
larry barnhart
wenatchee. wa usa
Hung walls have come loose from the studs. I know of a monaco that had the left side removed and reglued. $7000.00 because monaco went belly up and he lost the warranty.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Chris
Shelter Bay, Wa
Our Cardinal is vacuumbonded, aluminium stud walls. Also roof aluminium truss. Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
bogeygolfer
I realize this is a 5th wheel forum, but do any of you know of any travel trailer brands that use the "hung wall" method?
