jetboater454
Camping or home
Can you run 12V through household wire? I have a few hundred feet of it laying around and was wondering if I could use it for the main 12v power line.Seems like it would be easier to run,can fuse it bigger at the source with smaller fuses on the tap ins.Need more light in the TH garage.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
pianotuna
Regina, SK, Canada
Hi,
I'd double up on it--if you have two colors use one for positive and the other for negative. #14 x 4 = about #10 x 2.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
TomBird
North Carolina
Go to "12 volt side of life" and it shows you can carry 10 amps up to 10 feet in 14ga. Happy camping Tom
jetboater454
Camping or home
Why only a short 12v run? I would seem like you could run it for miles considering how big the wires are.Am I missing something trying 12V? You can have a long run in a house with it.
tvman44
Southwest Louisiana
For no more than 15 amps.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
smkettner
Sure you can, good for 15 amps. I would still buy wire to avoid any confusion between 120v & 12v. Or possibly remove it from the sheath.
675 watts solar
pianotuna
Regina, SK, Canada
Hi,
Yes, amperage is what determines wire size. The lower the voltage the more voltage drop becomes an issue.
A wire will get just as overheated from 20 amps @ 12 volts as it will at 20 amps @ 120 volts. The difference is that 20 @ 12 is only 240 watts--whereas 20 @ 120 is 2400 watts.
jetboater454 wrote: Why only a short 12v run? I would seem like you could run it for miles considering how big the wires are.Am I missing something trying 12V? You can have a long run in a house with it.
jetboater454
Camping or home
OK,thanks.Mainly was thinking of the sheath to protect the wires.I can strip the ends back so the sheath can't be seen so as not to confuse the next owner if we ever sell it.
Chris
Shelter Bay, Wa
Stranded wire is normally used in boats and RVs in the 12V systems. It flexes better and handles vibrations better. DO IT RIGHT!
Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
NORM WADDELL
PENSACOLA FL 32514
So that everyone understands
The INSULATION (wire covering) is selected for the
VOLTAGE (not CURRENT) involved. I have seen a piece
of insulated thermocouple wire connected to 115 v a c
and it SMOKED......the insulation burned immediately.
The COPPER SIZE determines the current limitation.
The insulation is selected for the VOLTAGE (and may
have to be specially chosen for high temperature or
chemical areas). As a general rule, insulation meant
for 120 volt use is rated at 600 volt A C
, and may be safely used for low voltage D C
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
