RV.Net Open Roads Forum: Tech Issues: Completed my solar installation
 > Completed my solar installation
trailrider
new plymouth, idaho
Posted: 02/20/12 04:25pm Link  |  Print  |  Notify Moderator
Very nice install, it's nice to see a job done right. If you would have paid someone to do the job, it wouldn't have turned out near as nice.
I am confused on one thing though. You have a Xantrex Truecharge 2 that is a 40 amp battery charger and now you have added an Iota 45 amp converter that charges the batteries as well. What's the reason for this?
2012 Chevrolet 2500HD
1978 Chevrolet K20 4x4
2003 Komfort 28TS TT
2012 Honda CRF450X
2004 Honda Rancher 400AT 4x4
2005 Honda Recon 250 ES
2007 Suzuki DR 650
renoman69
Edmonton Alberta
Posted: 02/20/12 05:07pm Link  |  Print  |  Notify Moderator
trailrider, Very good question. Here is the story. When I bought my fiver about 3 years ago I quickly discovered that the converter that Jayco put in was an elcheapo single stage converter that had a run of #10 wires well over 25 feet to the batts for charging. When plugged into to shore power or on genny it just would not charge the batts so I decided to get myself the TC2 and mount it right next to the batts for some quick charging when needed. This worked well it is a very good charger. Then one day while plugged into shore power there was a voltage drop or maybe a surge which fried my converter. At this point I needed a new converter. Talked to Randy at Best Converter who said that the Iota with IQ4 was the best route to take but I only had 10awg wires so I had to use the 45amp model. So I ordered it. Once it arrived I realized (with input from guys on here) that I would be better off mounting the new converter right next to the batts and "backfeeding" to the distribution panel. This worked out really well but now I have a bit of a redundant system. On hindsight I wished I would have ordered the 55 amp Iota and not the TC2 however the TC2 has an equalize setting that the Iota does not and I have the option of running them both together for a super fast charge although I have not yet tried to see if my Honda 2000i will run both at the same time.
2009 Jayco Eagle Superlite 25.5RKS
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I,
270 watts of Kyocera solar
Blue Sky 3024i MPPT controller
450 AHs of Trojan power
Iota DLS-75/IQ4 converter
cargovanconversion
Florida, USA
Posted: 02/20/12 06:30pm Link  |  Print  |  Notify Moderator
Great install. In a couple of months, I hope to do the same. Hope to do it as neat as you did.
Van.
My website describes the conversion of my Dodge B-250 van into a small RV. I deal with a lot of woodworking, but hope to be quite specific on solar as well.
cargovanconversion.com
jolooote
Miami, FL
Posted: 02/20/12 06:40pm Link  |  Print  |  Notify Moderator
Why do people bother with using conduit? Why not just run the wires?
Joe&Charlotte, Nat'l SurfSide DE34D Ford 362HP 5speed
Rusty, Rosie, Snuffy Dogs
Leroy's a Conure
If a 'Little' is good, 'Alot' ain't better.
nvreloader
Western Nevada
Posted: 02/20/12 08:33pm Link  |  Print  |  Notify Moderator
Renoman 69
Where did you find that J Box at?
Outstanding install, you gave me something to shoot for.
Tia,
Don
2010 F-350,6.4PSD, 6spd man trans,CC,SWB,SRW, Caravan camper shell,50 gal bed tank,17,000lb Husky WD hitch,Northwoods 2008 28KS Desert Fox Toy Hauler,2005 Honda 500 Rubicon ATV w/rumble seat,1 Aussie waiting,watching and ridin shotgun on the whole outfit.
renoman69
Edmonton Alberta
Posted: 02/20/12 09:26pm Link  |  Print  |  Notify Moderator
Used the conduit because the wires are running through the kitchen cabinets, pantry and out through the roof. There is a chance that things could fall over and rub against them. This is also run in the very rear of the fiver where things have a tendency to bounce around.
* This post was edited 02/20/12 09:35pm by renoman69 *
renoman69
Edmonton Alberta
Posted: 02/20/12 09:35pm Link  |  Print  |  Notify Moderator
nvreloader wrote:
Renoman 69
Tia,
Don
nvreloader, I bought the components at HD and the buss bars at my local electrical wholesaler. Some of the buss bars parts were salvaged out of old electrical panels.
Canadian Rainbirds
Vancouver Island (Winter: Mainland Mexico)
Posted: 02/21/12 10:26pm Link  |  Print  |  Notify Moderator
I am in the process of the planning the cleaning up the so-called professional installations of our system: 2 80 watt and 2 130 watt panels, Blue Sky Solarboost 2000E controller.
Damn you for setting the bar so high!
