RV.Net Open Roads Forum: Class A Motorhomes: Clogged black tank. Help!
 > Clogged black tank. Help!
Fire Instructor
Upstate (Albany) NY Area
Posted: 06/09/11 03:14pm Link  |  Print  |  Notify Moderator
If the angle of the toilet pipe won't let you put a high pressure wand down the hole, then pick-up a Tornado Flush and read the directions carefully. Drill the hole for the Tornado Flush opposite the dump pipe, where it's supposed to be, then use the hold to insert the high pressure wand until you get the solid block broken up and flushed. Then install the Tornado.
Fire Instructor
2014 Ram Laramie w/6.7L Cummins Diesel with Automated Safety Hitch
2016 Jayco 377RLBH
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
rvten
Crossville,TN
Posted: 06/09/11 03:32pm Link  |  Print  |  Notify Moderator
Look for a water flushing wand that is flexible. I carry one with me all the time. Can be used from inside or outside. Like Wolf says. If flushing from the outside. Be over a dump spot.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
Tom N
Sarver, PA/Crystal River, FL/Shelocta, PA
Posted: 06/09/11 04:18pm Link  |  Print  |  Notify Moderator
I was in FL and my neighbor was having black tank problems with his 5th wheel. 5th wheel toilets may not empty directly down into the black tank like most motor homes do. They have a run of pipe that may have a few 90 degree bends before emptying in to the black tank. This set up is more prone to blockage.
My neighbor called a mobile RV service. The repairman had his blockage cleared in minutes.
What he used was a piece of cable (wire rope) about 3/8 inch in diameter. He pushed it in and out of the toilet drain until the cable broke up the clog. Took only a minute.
Go to Lowes or Home Depot and buy 6 feet of 3/8 inch cable and try this procedure.
-Tom
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2013 Honda Accord EX-L · 2008 Honda Odyssey EX-L
hershey
Albuquerque,(fulltime) NM, USA
Posted: 06/09/11 04:33pm Link  |  Print  |  Notify Moderator
You may have indeed dumpted the black tank and your only blockage is the pipe directly from the toilet into the tank. A plumbers friend will prove this theory and free the clog.
If the tank is indeed clogged, you can get a cap that will twist onto the dump hose fitting and has a garden hose connection. Walmart will have it. Use it and gently apply backwards water pressure. Make sure that it doesn't overflow your toilet.
If that fails, the hose others have recommended to go into the tank is a good suggestion.
hershey - albuquerque, nm
Someday Finally Got Here
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
checkmate
Jacksonville, FL
Posted: 06/09/11 04:35pm Link  |  Print  |  Notify Moderator
This may help.
http://sites.google.com/site/cbruni/home
wolfe10
Posted: 06/09/11 04:38pm Link  |  Print  |  Notify Moderator
checkmate wrote:
This may help.
Clickable: http://sites.google.com/site/cbruni/home
Brett Wolfe
2003 Alpine 38'
old guy
Oregon (pronounced Or e gun)
Posted: 06/09/11 05:39pm Link  |  Print  |  Notify Moderator
sounds to me you are not using enough water when using the toilet. they make a power wand with a hose on the end to put down toilets with a curve in the down pipe.
96Bounder30E
America is my home!
Posted: 06/09/11 04:52pm Link  |  Print  |  Notify Moderator
Get a flush king.......fill and dump until your holding tank dumps completely........
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
KarenInTheWoods
Wisconsin
Posted: 06/09/11 06:28pm Link  |  Print  |  Notify Moderator
Our friends had a clog. They were lackadaisical about how they dumped or how much water was added to the tank after dumping.
Until they had a Black Pyramid.
They boiled five or six large kettles of hot hot water on the stove, and dumped them into the tank and let it set. Loosened things up and flowed again.
Now they are firm believers in leaving the black tank closed until 3/4 full and then pulling the lever with a good WHHOOOSSSHHH and rinsing again and again when done. And then adding 2 gallons to start anew.
Karen and Steveio
Safari Serengeti 38 ft DP
Tracker 4x4 Toad
(My RV Blog RVing: Small House - BIG Backyard
(Camping/Family Photos) http://picasaweb.google.com/pfundt/
Mergs
Sayville, NY, USA
Posted: 06/10/11 07:48am Link  |  Print  |  Notify Moderator
Had trouble and went on line until I found this soulution. Turn off handle to black tank. Take the hose out of drain and hold it up above your head and fill with water from little hose. Have someone help you and hold up the middle of the fat line until the water backs up and hits the clog and quickly put the fat hose into the dump. It quickly emptied the black water. But my husband had filled the whole black tank before hand trying to unclog it. Hope this is understandable.
