RV.Net Open Roads Forum: Class A Motorhomes: Siliconing rubber gaskets on slides
 > Siliconing rubber gaskets on slides
grammygiel
Eagan, MN
Posted: 06/10/11 08:23am Link  |  Print  |  Notify Moderator
Can anyone give me advice on applying silicone spray on the rubber around the slides without damaging the paint? I have a spray can but I'm afraid overspray would be a problem.
downtheroad
Pacific Northwest
Posted: 06/10/11 08:25am Link  |  Print  |  Notify Moderator
I doubt that silicone will damage your paint...but if you want to control the application, spray the silicone on a rag and wipe it on the seal.
303 Protectant is a good product for this.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
BigSkyBob
Helena, Montana
Posted: 06/10/11 08:30am Link  |  Print  |  Notify Moderator
I second the suggestion of using Aerospace 303 on the slide seals, along with everything else that is rubber.
2008 Monaco Camelot 40PDQ, 4 slides, 2012 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 7200 GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
fordsooperdooty
Posted: 06/10/11 09:10am Link  |  Print  |  Notify Moderator
Silicone is a chemical derived from petroleum and contains distilled petroleum.
The bad news is that slicone can dry out rubber and synthetic rubber gaskets, causing them to age faster and loose the "plasticizers" in the rubber. Also...the silicone can cause the rubber seals adhesive to fail.
Just 303 Aerospace will stop the sun damage, keep the seals safe and supple, stop sun and ozone damage and also will lube the seals. Same stuff will keep tires safe and prevent ozone damage too.
jerseyjim
New Jersey
Posted: 06/11/11 03:35am Link  |  Print  |  Notify Moderator
I got this spray from CW...."lubricates the slide-out gaskets...and will not damage paint".
Used it twice so far...no problems.
livingaboard
Everett wa
Posted: 06/11/11 08:38am Link  |  Print  |  Notify Moderator
surprisingly enough, I found the 32 ounce 303 at my local West Marine boat store for about $21 and some change. The local rv parts place wanted $27 and some change. It makes my tires look great
Dave
Everett, WA
2000 Itasca Suncruiser 35U, F53 Triton V-10
Firestone air bags with Quad control air gauge
Pressure Pro tire pressure monitor
Banks Exhaust
SuperSteer rear trac bar
Olympian Wave heaters (Wall mount and portable)
JimFromJersey
Southern New Jersey
Posted: 06/11/11 09:27am Link  |  Print  |  Notify Moderator
+1 on the 303 Aerospace Protectant - have been using it for years on my cars and other various appliances. UV blocking is just one of its many good qualities. Almost anything NON-porous can benefit from it.
Spray on, let soak in or spray on and wipe off. I give the tires a couple of good healthy sprays every month or so and walk away. They look good and the 303 helps them resist UV and dry rot.
303 is one of those products like WD-40 and 3-in-1 oil that everyone should have a supply of.
303 also makes a very good fabric guard product that adds water resistance, UV blocking, and other good stuff for things like outdoor furniture cushions, awnings, umbrellas, et cetera.
(I have no financial interest in this product, I just like helping others see the light!)
"For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled." - Richard Feynmann, Challenger Space Shuttle Hearings, 1986
