RV.Net Open Roads Forum: Class A Motorhomes: Carrying flares
 > Carrying flares
Page of 5
bigred1cav
ohio
Posted: 04/30/12 03:28pm Link  |  Print  |  Notify Moderator
We used the ones with spikes on the end. I didn't like them, thought they could cause blowouts.
Doug and Cassi Glass wrote:
Let me give you my two cents worth after 33 years on the CHP.
We used tons of flares and they work GREAT if you know how to deploy them. While they can be used to move traffic away from you, if the pattern is wrong it will actually funnel traffic right into your vehicle.
At freeway speeds a flare pattern has to be several hundred feet long to work effectively. Way more than 3 or four flares.
Assuming you put out your 3 30 minutes flares in a pattern, what do you do when they all burn out? 30 minute flares last about 20 minutes and 20 minute flares last about 13-14 minutes.
Lighting flares is dangerous and the glowing embers that shoot out when striking them can blind you. ALWAYS turn your head to the side.
1. Don't throw the cap away.
2. Stick it on the butt end of the flare.
3. The little tit in the cap keeps the flare from rolling off the road.
There are actually two caps, a small, thin one that protects the striker. Throw the little one away.
4. Take the big cap off and hold it firmly at arm's length.
5. FIRMLY swipe the end of the flare that was covered by the cap across the cap AWAY from your face. It's like striking a big kitchen match.
6. Don't kept the molten material drop on you. It will instantly destroy your shoe.
7. Gently lay the flare on the ground. If you throw it they pop a spew crud everywhere.
8. If you have to put one out, gab it by the butt end and stub it out like a big cigarette.
All that being said, buy, carry and use the triangles. They're safer, more effective day or night, reusable, and don't burn out like flares.
I'LL SHOUT THIS LAST TIDBIT. IF YOU EVER ABSOLUTELY HAVE TO GET OUT ALONG SIDE ANY BUSY ROAD NEVER, EVER TURN YOUR BACK TO TRAFFIC FOR A SECOND. Have a spotter who is standing toward the front of the vehicle so they are facing traffic going in your direction as it approaches so they can warn you of impending danger.
Best advice is limp off the freeway. Most likely reason for stopping is a flat tire and it is already ruined so drive off slowly to a safe spot.
Flares don't last forever in your trunk. They get bad after 2-3 years so don't expect those you bought 15 years ago to burn or even light. We used to get quite a few duds out of new boxes.
zman-az
Northern AZ
Posted: 04/30/12 04:53pm Link  |  Print  |  Notify Moderator
This thing is pretty neat.
wny_pat
Western NYS
Posted: 04/30/12 05:12pm Link  |  Print  |  Notify Moderator
$10 cheaper at Duluth Trading Post. And I got them cheap enough that I ordered ten at Christmas time for gifts. Got a even better deal then ($18 each)! Kept 3 for myself.
Jarlaxle
New England
Posted: 04/30/12 07:14pm Link  |  Print  |  Notify Moderator
slickest1 wrote:
Years ago when I started driving commercially you only used your 4 way flashers when you were broke down on the side of the road or stopped at an accident scene. Now the driving schools teach new drivers to use them going up and down hills when moving slower than the speed limit. Hence nobody pays attention to 4way flashers anymore. I like the commercial triangles as well.
Some states (offhand, Pennsylvania) REQUIRE their use when below a certain speed on the highway.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
landman02
Oklahoma
Posted: 05/05/12 09:41pm Link  |  Print  |  Notify Moderator
Where do you get triangles that are heavy enough as not to blow over when a big rig goes by? Also, heavy lighted ones.
wny_pat
Western NYS
Posted: 05/05/12 09:53pm Link  |  Print  |  Notify Moderator
Any truck stop store or heavy truck supply house. The bases are weighted. But the lighted triangle ones???
Page of 5
 > Carrying flares
