Slayerman
Calgary, Alberta
What would cause your grey tank to say it is 2/3 full even after you have dumped the tanks?
Thanks, S.
My Website: Alberta Campsites
My Blog: RvBlogs.net
2005 Chevrolet Avalanche
2012 Shadow Cruiser 280QBS
mick/linda
nf
dont believe everything you see...those little red lights are not worth the effort to press the button...when you dumped,did it seem like a full tank emptied,thats usually what I go by
mick/linda
nf
oh,and as far as the cause,maybe a little bit of onion on the sensor,ha,ha.....seriouly though,those sensors are prone to giving wrong readings.......there are chemicals that advertise to keep them clean,but like I said before,dont believe everything you read
mick/linda
nf
by the way slayerman,hows everything in Calgary...lived there for a bit back in the late 80's early 90's....still got 2 sisters there
ArmySFCRet
Moving to Congress, AZ
If it quit runnin' it's empty.
'04 Cross Country 35' w/300 Cummins
'05 Sebring CV on KarKaddy 460SS
'09 Dodge Ram 1500 4x4 Crew 5.7 Hemi MDS
'51 & '53 Hudson Hornets 308 6cyl w/TWIN H-POWER
5 lbs of BG the Yorkie
Members of:
Grand Canyon Chapter of Hudson Essex Terraplane Club Inc
Bonefish
Midland, TX
Food and gunk going down the drain sticks to the sensor area and causes miss readings. I don't think ours have read correctly since it was new. Don't worry about it. I can check the black tank with a flash light looking down the drain. Gray water tanks we have learned to conserve if we are going to be on a week or more stay.
If you are still concerned the only way to check if it is fully draining is to fill the tank until it backs up in the sink or bath tub. Then use a five-gallon bucket measure the gray tank volume and see if it matches the manufacturers volume.
Bonefish
scottsnider
Buena Park
I like what ArmySFCret said, when it stops draining its empty, I got one of those clear plastic drain parts that hooks on and then you put your hose on and then I can see it flowing. Like he said when it stops flowing its empty.
Slayerman
Calgary, Alberta
Thanks for all the info.. everyone. I will try what you all have suggested. just glad it is not something major. I will give the 5 gal bucket thing a try. just interested to know if it is just us over using or if there is a tank issue.
BTW. mick/linda Calgary is great... just too big now. it is always nice in the summer.. and darn cold in the winter. lol.
S.
wmoses
Houston, Texas, USA
Slayerman wrote: What would cause your grey tank to say it is 2/3 full even after you have dumped the tanks?
Some garbage or the other from the kitchen sink. Same thing happens for the black water toilet, in which case it could be toilet paper.
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
Gene&Ginny
North Kingstown, RI
Sometimes even a little soap will cause it to show 2/3 after dumping. Often after dumping at a campground it may show 1/3 or 2/3 and then when I get to the next campground many hours later it shows empty.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
