RV.Net Open Roads Forum: Tow Vehicles: Toyota Avalon or other sedan tow vehicle?
Search only in Tow Vehicles
 > Toyota Avalon or other sedan tow vehicle?
twaldher
Bremerton, WA
Posted: 06/17/11 04:25pm Link  |  Print  |  Notify Moderator
clydengail wrote:
I think the biggest problem with using sedans for towing is the suspension. These days, most are built for comfortable ride, not load carrying. Vans and SUVs are a different matter.
Unless you go back to land yachts of the 70's.
Part of me would think it fun to stroll in to camp hauling your TT behind a top down cadillac. LOL
1998 Chevy Crew Cab 4500 4x4 454, Auto, 4.10 Gears
2003 Nomad M-308 (30', bunks, 14' slide)
Prodigy P3 Brake Controller
ib516
Up here!
Posted: 06/17/11 04:26pm Link  |  Print  |  Notify Moderator
The new Durango and Jeep Grand Cherokee get pretty good mpg when equipped with the new Pentastar V6. Rated at over 23 mpg hwy (US).
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
jerem0621
Sequatchie, TN
Posted: 06/17/11 08:34pm Link  |  Print  |  Notify Moderator
I am not advocating this by any means, but here a thread I had to reach way back into the server memory for, dust it off real good so the link would stick. (JK)
This fella set up and successfully towed a 34ft airstream with a Dodge Intrepid!
I think his name is Andy from Can Am RV in London, Ontario.
Again, check my sig to see where I stand on this issue, but the reading is interesting.
Clicky
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Ron3rd
Upland, CA USA
Posted: 06/17/11 08:51pm Link  |  Print  |  Notify Moderator
Andy from Can Am RV in Canada has made a living setting up Minivans as well as other vehicles, to tow Airstream trailers. You can easily google his info, or go here: Can Am
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
jroden
buffalo
Posted: 06/18/11 04:35am Link  |  Print  |  Notify Moderator
Thanks, I live near Buffalo NY so am familiar with andy, he suggested I look at the New Taurus, VW Diesel and the Buick Lacross w/ V6. I do like that VW wagon w/ diesel but never see them used.
jroden
buffalo
Posted: 06/17/11 06:35pm Link  |  Print  |  Notify Moderator
gregrc75 wrote:
I think the Subaru Outback Wagon with the V6 tows 3200lbs. A friend of mine has the Subaru Outback wagon with the 4 cyl and her's tows 2800lbs
I had a forester with the turbo and threw the 10 foot pop up on it to run down the road 10 miles. It was good on power but the soft springs and short wheelbase would require some sort of weight adjusting hitch.
I have to wonder about towing close to the limit with a turbo engine, though they tend to rate the turbos quite a lot higher.
jyh818
Chino, CA
Posted: 06/28/11 08:24am Link  |  Print  |  Notify Moderator
I was in the same dilemma a couple of years back. We have a '98 Camry, '01 4Runner, and '07 Sienna and wanted to get a travel trailer with all the creature comforts. The 4Runner had the highest capacity at 5K lbs., but that left no payload. We looked at Trailmanor and was shocked at the price tag for one of those. Plus it would be close to our max towing capacity.
We ended up just getting an Excursion to tow with. This allowed us a lot more options in a trailer we wanted. The cost of the used Ex and new trailer was just about the same cost as a new Trailmanor. The good thing about going this route was I am not jeopardizing my safety being at the max towing capacity.
2002 Ford Excursion XLT 6.8L V-10 2WD, 4.30 Limited Slip
Rear Hellwig Sway Bar
2009 Skyline Nomad 260
EAZ-Lift WD Hitch
RobertRyan
Australia
Posted: 06/26/11 08:00pm Link  |  Print  |  Notify Moderator
We use sedans with a 5000lb towing capacity to tow lightweight Caravans mainly on pavement in Australia.
rexlion
Broken Arrow OK
Posted: 06/26/11 11:50am Link  |  Print  |  Notify Moderator
My '08 Highlander is unibody, and has a 5000 lb. tow / 500 lb. tongue capacity. Funny thing is, when I test drove it, the salesman bragged about the great ride by saying the Highlander was built on the same platform as the Avalon. Go figure.
Like others have said, the Avalon suspension may not be able to handle much tongue weight. Maybe that is whey they don't rate it for towing. The 3.5L with 5 speed auto is a great combo though. I have towed a (approx.) 3500 lb. trailer more than 75,000 miles with my Highlander and it does fine. Have not needed anything but fluids and filters, with 91K on the odometer.
Mike & Sherry
2000 Mercury Mountaineer
2008 Toyota Highlander
2011 KZ Spree Escape E14RB
BenK
SF BayArea
Posted: 06/26/11 12:20pm Link  |  Print  |  Notify Moderator
The 'first' gen Highlander was derived from the Camry, which is also
the basis for the Avalon
The 'current' gen Highlander is derived from the Sienna
Both monocoque or unibody
OEM's limit things via several methods. Like I used to say 'no' to
any company wishing to license something my company didn't want to.
Tell them the cost is $1,000,000,000 per year plus royalties. That is
saying 'no' without saying 'no'...and if they were foolish enough to
do so, my company would have rewarded me with a big bonus for setting
a hook on that fish...
An OEM can limit the trailer by their tongue rating and if someone did
find a trailer with that tongue weight...it would most likely be an
ultra light and/or a 10% tongued trailer.
Longevity and safety are the issues with using things at or over their
limits.
Going over or always at the limits won't have the wheels instantly fall
off, but they will sooner. Plus that day when Mr Murphy crosses your path
-Ben Picture of my rig
