RV.Net Open Roads Forum: Norcold Refrigerator Vent Fan Install with Switch (pics)
 > Norcold Refrigerator Vent Fan Install with Switch (pics)
ElPasoTom
El Paso, TX
Posted: 06/18/11 08:26pm Link  |  Print  |  Notify Moderator
Also see inside fan mod if you're interested.
Inside Fan Mod Clicky
With temps in El Paso over 102 again today I realize my refrigerator is struggling to maintain temperature. Mid-day temps showing 42-43 inside the fridge. I prefer 36-38 so I thought I'd put a little fan behind the fridge to help move things along.
I've seen fans designed for this purpose but I wanted a less expensive solution, and besides the space back there is tight and I didn't want to move anything.
Parts for this job
Trying to find the ideal place was difficult but I chose a location that was easy, allowed for simple install and was easy to service later.
I wanted to be able to switch the fan off when the temps were lower so I needed a place for the switch. I mounted a piece of scrap wood and screwed in the switch mount.
Now for all the wiring. I searched the internet for hours looking for best way to wire this as I am not electrically gifted..... at all. I saw the package the switch came in and it looked pretty basic so I gave it a try.
Hooked up the hot (with a 1/2 amp fuse from Radio Shack). Load connector went to the fan red wire. The fan blue wire went to the switch ground and to the ground in the rear panel. Held my breath and clicked the switch... it works!
Now to mount the switch and make the connections permanent.
I will have more data tomorrow but the fridge began cooling down quickly and I've set it for "3" instead of "4" so we'll see if the temps hold 38 deg on a lower power setting since tomorrow will be over 100 again.
Hope this mod helps someone else tackle some wiring. Nothing fancy but it moves air and that's all I wanted.
2014 Chevy Duramax 2500HD 4x4
2008 Suburban 2500 LT 4x4
2009 KZ Spree 289KS
CISCO8325
Peoria,az.
Posted: 06/18/11 08:30pm Link  |  Print  |  Notify Moderator
like it
GENECOP
NEW YORK
Posted: 06/18/11 10:27pm Link  |  Print  |  Notify Moderator
Thanks, it helps, I will be going for it any day now....
old guy
Oregon (pronounced Or e gun)
Posted: 06/18/11 11:29pm Link  |  Print  |  Notify Moderator
I did that to mine only yours looks far better than my install. esp the switch holder
Gale Hawkins
Murray, KY
Posted: 06/18/11 11:42pm Link  |  Print  |  Notify Moderator
That is a nice job.
After I installed ours I read where you need to extend a duct like shield above/below the fan a few inches so exiting air flow does not in part get sucked back in on the intake side. In your case you could test it really easy.
ElPasoTom
El Paso, TX
Posted: 06/19/11 08:13am Link  |  Print  |  Notify Moderator
Link to Switch
The switch I used.
Link to fuse holder
The fuse holder.
I also bought a package of (4) 1/2 amp fuses.
ElPasoTom
El Paso, TX
Posted: 06/19/11 08:16am Link  |  Print  |  Notify Moderator
Gale Hawkins wrote:
That is a nice job.
I saw this with other fans, but I don't really have the space. Even with the inefficiency hot air rises, and all I hope to do is give it a little push.
Depending on how this performs I may also later add the solar powered fan for the top of the vent area. I don't plan on camping in the really hot areas if I can help it. I'm out of here Tuesday for the Grand Tetons and Yellowstone where I probably won't need the fan at all. [emoticon]
ElPasoTom
El Paso, TX
Posted: 06/19/11 08:21am Link  |  Print  |  Notify Moderator
TEMP Update!
This morning the refrigerator was 37.2 degrees on setting 3 out of 5. It's 75 degrees at 6AM going to 105 deg this afternoon. I do not think the fridge can keep up with these extreme temps so I may have to go to 4 or 5 to keep temps down, however using 3 instead of my usual 4 is an improvement.
I also have to realize a gas absorption refrigerator can only do so much.
Ron3rd
Upland, CA USA
Posted: 06/19/11 09:31am Link  |  Print  |  Notify Moderator
Nice job ElPasoTom,
Just a quick question; what's the idea behind this mod? Is it to push the air "up" through the roof vent, and thereby increase efficiency?
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
ElPasoTom
El Paso, TX
Posted: 06/19/11 09:40am Link  |  Print  |  Notify Moderator
Ron3rd wrote:
Nice job ElPasoTom,
These refrigerators remove heat by absorbing it through fins inside the refrigerator, then release it behind the refrigerator in the space between the fridge and the wall of the trailer.
Convection should bring in cooler air from below and "chimney" the warmer air out of the roof vent. As the temperature rises from ambient air, then the difference between the incoming air and air inside the vent space shrinks and you lose the "convective" movement.
A fan is supposed to help move that warmer air up and out of the vent helping retore some efficiency to the fridge in warmer temps.
At least this is how I understand it.
