RV.Net Open Roads Forum: Class A Motorhomes: Flush toilet = sewer smell. Suggestions
 > Flush toilet = sewer smell. Suggestions
fcooper
Richmond Hill, Georgia
Posted: 06/21/11 07:07pm Link  |  Print  |  Notify Moderator
klm wrote:
OK,
I don't want to dump at my present cg, near Charleston - the water smells like rotten eggs - don't need that on top of sewer stink!!!!!!!!!!!!! So any suggestions to get rid of "peppie la pew"???
I also think your black water level is above the vent opening. If it were me, I'd dump now, put some of that stinky rotten egg water into the black tank to keep things wet, and then dump/flush again at the next campground. If you don't want the rotten egg water in your fresh water system, you can pour a couple of gallons into the toilet with a bucket that you fill outside.
I hope you get the problem resolved.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
johnsonbert
Houston, TX-Ironwood, MI
Posted: 06/21/11 08:19pm Link  |  Print  |  Notify Moderator
If the air conditioners are running steady, is there a possibility that the exhaust from the air conditioner is blowing over or down the vent pipe and driving the air back into the toilet when flushing? You might check the proximity of the vent pipes to the air conditioner exhaust. Just another possibility to check. Happy Trails Bert
2003 American Tradition 40W 350 Cummins
2010 Chev Malibu LT
pacific-sun
British Columbia, Canada
Posted: 06/21/11 09:41pm Link  |  Print  |  Notify Moderator
If you have a washer/dryer combo unit try running a cycle through to fill the "P" trap for them. If they are not used often they will dry out..
Dave.
1998 38ft Beaver Contessa DP 1 slide 330 Cat.
2002 Saturn L300 1992 Honda Goldwing 1500 SE
sum1
So-Cal
Posted: 06/22/11 12:08am Link  |  Print  |  Notify Moderator
As Old Guy suggested. Make sure the fan is off when you flush.
* This post was edited 06/22/11 05:39am by an administrator/moderator *
Lobstah
Northeast
Posted: 06/22/11 05:52am Link  |  Print  |  Notify Moderator
When you dump, are you opening black first, then opening gray to flush things out once black is done?
That's the most common method.
If that's the way you're doing it, it's the only time that the gray valve and the black valve are both open. With that situation, if you have ANY trap that has dried out, it will allow gas from the campground septic system to flow back into your coach through the vent that has the dried out empty trap.
As mentioned by pacific sun, check washer dryer trap, shower trap and all sink traps. With an empty trap, the only time you wlll get odors is when you're connected to a sewer hookup and both valves are open.
All it takes is one. When we set up, one of the things on our checklist is to run water through every drain, which is shower and 3 sinks for us, because the traps dry out while sitting in our driveway.
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
john and terry
Posted: 06/22/11 07:18am Link  |  Print  |  Notify Moderator
odie1234 wrote:
A cup or so of bleach in the tank will kill bacteria and odors, but you will lose any digestion going on.
Again I say, you have no digestion going on anyway. Black tanks are holding tanks...not digesters. Digestion additives are a scam.
Unless you monitor dissolved oxygen levels, Biochemical Oxygen Demand levels, floc settling, dissolved solids levels, pH levels, treatment bacteria condition and such...you have no business even thinking about digestion. Lack of digestion is NOT your problem!!
Go with the bleach addition to clean water after a good dump and flush.
Full Timing In Our 1996 Winnebago Brave (P30/454)
...Check Out Our Gate Guarding Blog HERE!
TOAD - 2010 Nissan Cube
With 2 Fairly Well Behaved Diggities
Venus And Midnight
whit6
taranaki
Posted: 02/26/12 08:09pm Link  |  Print  |  Notify Moderator
hi
myself and a friend of mine have a 1995 and 1996 kountry star a class diesel.
if our tanks are full and we drive away to a dump station our motorhomes start smeling either black or grey water (not sure) but think black.but if we only have say around a 1/4 tank they do not smell while driveing.only when they appear over 1/2 full
any help appreciated.
Yankee Clipper
Cairo, GA
Posted: 02/27/12 07:57am Link  |  Print  |  Notify Moderator
Just a thought: turn the exhaust vent fan off before flushing.
Yankee Clipper
1997 Coachmen Catalina 330MB on F53/Ford 460efi
1991 Explorer Sport 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS
Not overly concerned about depreciation with this rig...
Paul Turpin
Surprise,Arizona / Cincinnati,Ohio
Posted: 02/27/12 08:54am Link  |  Print  |  Notify Moderator
Just clean your tank out. Just before you leave the campground, flush out your black tank with water several times (fill it ALMOST to the full mark and dump). Then fill tank 1/4 full of water, whole bottle of pine-sal and just before you drive out of campground put two bags of ice down the toilet. When you get to the next campground dump that mix and your tank will be ok. The ice driving down the road helps to remove any hard stuff that sticks to the walls and bottom of the tank.
If you take your rig in for this at a RV service center, the first thing they do is flush out your tank, put 50 pounds of ice down the toilet, drive your rig a few miles around then charge you $80 for "cleaning your black tank" listed on the bill.
Good luck
Paul and Sue
2004 Pace Arrow 37C
Workhorse
2006 Saturn Ion
jvander
Indianapolis
Posted: 06/23/11 11:15am Link  |  Print  |  Notify Moderator
No idea why you're having odor problems all of a sudden. We use Odorlos and are very pleased. No sewer odors, no chemical smell, no perfume smell. I recommend it.
1993 Coachmen Catalina 31'
Chevy P30, 454 TBI, Hedman Hedders w/ x-pipe and Jones Full Boar mufflers. Same mileage as stock exhaust, but we get there faster!
Looking for a better rig...
