RV.Net Open Roads Forum: Tech Issues: EU3000 is Honda,Questions
 > EU3000 is Honda,Questions
Welder99
Rushsylvania Ohio
Posted: 06/21/11 07:28pm Link  |  Print  |  Notify Moderator
Hello,This is to the eu30000is owners..(Or anyone that knows) :0)
Anyway I would like to know how long this unit will run on a tank of fuel running an 13,500 Btu Roof Air?.Also can you run the unit on the econ mode when running the air.I have a Duo Therm roof air....Thanks in advance.
2oldman
Wilson Creek WA
Posted: 06/21/11 07:59pm Link  |  Print  |  Notify Moderator
fwiw...
3000 won't run 15k air?
bgum
South Louisiana
Posted: 06/21/11 08:09pm Link  |  Print  |  Notify Moderator
My Honda 3000is will run my 13500 btu AC on eco mode. I have never tried to determine how long a tank of gas will last. The book states up to 20 hrs on eco. The 3000i is a little lighter and runs only 7.7 hrs on a tank. It also puts out less watts/amps.
TECMike
Temple, Texas
Posted: 06/22/11 04:02am Link  |  Print  |  Notify Moderator
My Honda 3000is will run my 13.5K AC just fine. However, I do not use the Eco mode on start-up. After it runs for several minutes, I switch over to Eco and it cycles the AC easily without any problems.
Might check the specs to see how long it is rated to run. Too, a lot depends on the current draw of other appliances you choose to run.
TECMike
Temple, Texas
Posted: 12/23/11 06:36pm Link  |  Print  |  Notify Moderator
Just a point to update, last summer our Honda 3000 struggled at 9,000 feet in the mountains to cycle our 13,500 AC compressor. So if you plan to do a lot of camping in higher elevations, you might want to consider a larger generator.
mikestock
Vestavia Hills, AL, USA
Posted: 12/23/11 09:08pm Link  |  Print  |  Notify Moderator
I don't know who got the idea that the EU3000is won't run a 15k air conditioner.
I have run 15k air conditioners for 10 years with my EU3000is. That's actually three different fifth wheels I've owned. I can switch to econo after starting the AC but if it tries to cycle off and back on in econo mode it will overload. I don't normally run the AC in econo unless it's a hot day and I know the thermostat won't cycle.
My current fifth wheel has a 13.5k and a 15k unit. I can run them both if I parallel the EU3000is and the EU2000i, but not in econo.
The original question is about how long it will run a 13.5k on a tank of gas. I would guess around 10 hours give or take. Never failed to make it through the night with my 15k on a tank of gas.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
sc3283
St Louis
Posted: 12/23/11 11:51pm Link  |  Print  |  Notify Moderator
I can say @ 1000' or less and 90 degrees or less my 3000i would run my 15k AC in my trailer just fine.
Prior to getting the 3000i.....the onboard Onan failed...I borrowed a 2000i....with everything off in the trailer...it ran the 15k AC fine...until the refridge turned on(I forgot to flip it to lp)
04 D-Max Crew Dually
96 Monaco Dynasty 36'
christopherglenn
a little over an hour from Yosemite
Posted: 12/24/11 12:03am Link  |  Print  |  Notify Moderator
If a 3000 is struggling, turn off the fridge and converter.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
77charger
fullerton ca
Posted: 12/24/11 04:41pm Link  |  Print  |  Notify Moderator
I have a 8.5 lance camper and on the way to lake powell we stopped 20 miles out of vegas warm at night.I ran the a/c all night from 10pm to 8am it cycled a few times over night and i usually just keep in eco mode.
I started with a full tank the next gas station it too 1.9 gallons of fuel to refill it.
Whoever says they wont run a 15k may be wrong.I had a friend who had a fiverwith a 15k who was interested in 2 2000s i asked why he said he heard a 3000 wont run it i pulled my truck up to his cord plugged in and told him start it it did and ran in eco mode just fine.
ryanallie1
Magalia, Calif
Posted: 12/26/11 09:15am Link  |  Print  |  Notify Moderator
Hi All.
Just remember that not all RV A/C's are created equal. Many RV A/C's take a lot more power at start up then others. Have you tried to install a "Hard Start Capistor" on your 15,000 BUT A/C ?. Our last 5er, our 13,500 BTU A.C had a hard time starting with Paralled Twin Honda EU2000i's. ( 4000 ) Our Owners Manual, clearly stated that our A.C needed at least a 3.5 KW ( 3500 ) Generator to even start ours, let alone run it. After I installed a "Hard Start Capasitor" the Twin Honda's easily started the A/C with no struggles what so ever. yes, it made that big of a differance. After the install, I was able to start our 13,500 BTU A/C on Echo Mode. I would give a "Hard Start Capasitor" a try, it just might make all the differance in the world to your A.C also. But at the least, if you turned off your Converter/Charger, Water Heater or anything else that uses electricty, you should be able to start your A/C, unless it just draws to many amps at start up, and that is where the "Hard Start Capasitor" come in to play. Give one a try. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
