RV.Net Open Roads Forum: Fifth-Wheels: A towing question
 > A towing question
ncognet0
Moab Utah
Posted: 06/24/11 10:50pm Link  |  Print  |  Notify Moderator
Hi, I have a question regarding tow weight. I own a 2008 Ford Diesel f-250 with a turbo, short wheel base and currently tow a tango 5th wheel. According to the charts on the ford website the tows 12.500 i am wanting to upgrade to an elk ridge 5th wheel that weighs14,075 lbs gvwr. Will my ford diesel handle this without hurting anything. Thank you in advance
bldrbuck
one or the other
Posted: 06/24/11 11:22pm Link  |  Print  |  Notify Moderator
I would say the overload will shorten your truck's life. Depending on what insurance company you have it may in case of an accident cause them to not pay.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 35' King of the Road 5er, 192 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 2 Trogan T105 Batteries, Me, my wife and 2 maltize furkids.
stickdog
29.820224, 81.94542
Posted: 06/24/11 11:40pm Link  |  Print  |  Notify Moderator
Why would his insurance care if the rig is properly tagged for the weight and he does goes over axle or tire ratings.
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Al B
Cowtown
Posted: 06/25/11 12:29am Link  |  Print  |  Notify Moderator
The 14075 would be a gross number, how often do we get to that number??? depends I guess. The truck will have no problem, probly the same as the 12500lber, 1600lbs isn't much difference, you probably wouldnt even notice. I also don't think you would be over on the axle weights or the tire weights, the important numbers IMHO... BUT, (dealing with insurance companies daily) I could see an insurance company denying a claim due to the overload.
Cummins Powered
Yahooligan
Temecula, CA
Posted: 06/25/11 01:10am Link  |  Print  |  Notify Moderator
Surprised nobody has mentioned this...
The problem the OP is going to have is his truck's GVWR/payload capacity, not just the tow rating. A 5er with a 14k gross is definitely 1-ton or more territory due to the pin weight.
Hogan & Clan
1989 Monaco Crown Royale 36 - Cummins 6CTA8.3
soling2003
Federal Way, WA
Posted: 06/25/11 01:27am Link  |  Print  |  Notify Moderator
The big thing to check is RAW. The truck will tow it fine, probably stop fine too, but you are getting close to the CVWR and I'm sure over the RAWR too. We had to get a dually as the 250 and 350 had the same CVWR.
DW and 2 dogs
2011 Ford F350 Dually LB 4x4 CC 6.7 diesel
2007 Grand Junction 35TMS
Peterson 37(just sold) T-37 R/C Sailboat at home
skipnchar
Topeka or somewhere else
Posted: 06/25/11 06:00am Link  |  Print  |  Notify Moderator
The Diesel will handle it just fine but the truck will be overloaded. Probably the BIGGEST concern is that the pin weight will more than likely be over your trucks payload rating when you also take into consideration other items in the truck like passengers, cargo, hitch, AND the loaded PIN weight. Check the door post for the GVWR and payload of your truck. If it doesn't list the payload (lots of older models do not) then weigh the truck and subtract the result from the GVWR to see how much additional weight the truck can carry.
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/25/11 06:46am Link  |  Print  |  Notify Moderator
14,000 lbs x 20% = 2800 lbs pin weight
Empty truck weight is likely 7500 lbs, before hitch, passengers, other cargo and pin weight are added.
Truck GVWR is likely 10,000 lbs.
10,000 minus 7500 = 2500 lbs payload capacity.
The loaded pin weight of the trailer, by itself, not considering passengers, hitch and other cargo in the truck, will put the truck over the GVWR by 300 lbs or so, assuming 14K loaded trailer weight and 20% pin weight. Further add 200-300 lbs for hitch, 300-600 lbs for passengers, unknown weight for other cargo, etc, etc. The truck will be well over the GVWR once all loaded up.
Empty rear axle weight of truck is likely 3000 lbs, before hitch, other cargo and pin weight are added.
Truck RGAWR is likely 6100 lbs.
6100 minus 3000 = 3100 lbs rear axle (tires/wheels/springs weight limits) load capacity.
With 2800 lbs of pin weight and 200-300 lbs for the hitch, the truck will reach it's rear axle weight rating before any other cargo or passengers are added to the truck.
Your truck does not have sufficient payload and rear tire/wheel/spring capacities to carry 2800 lbs of pin weight, plus hitch, plus passengers, plus other cargo in the truck.
You need to choose a trailer with a loaded pin weight of 2000 lbs or less and even then you will be very close to or over the GVWR of the truck but at least you will be under the RGAWR and tire/wheel/spring capacities.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Bill1374
northern New York
Posted: 06/25/11 06:59am Link  |  Print  |  Notify Moderator
My combination is very similar to what you are looking at. Truck handles the set up ok but does need either air bags or Timbrens to level out the squat. I'm slightly over the rated weights for axle and gross combined but no where near the legal weights. The combination works for me.
Bill
2011 Hitchhiker Discover America 345RSE
2006 Dodge quadcab,dually 2 wheel drive
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/25/11 07:26am Link  |  Print  |  Notify Moderator
Bill
If you're over the rear axle weight rating, you're over the legal weight. The rear axle/tire/wheel weight rating IS the legal weight limit for any vehicle.
 > A towing question
