RV.Net Open Roads Forum: Truck Campers: newbie battery question
 > newbie battery question
vern96
Washington State
Posted: 06/28/11 08:56pm Link  |  Print  |  Notify Moderator
This is my second season with my 2007 S&S 9.5 FSCB. I am going to put the battery back in it, and am confused at which lead goes where.
One lead is white, the other is black (with a red shrink wrap where the wire and eyehole connector meet. None of the owners manuals tell you which is which.
The wires are not marked "+" or "-" ..... white and black have both meant either or to me depending on the application.
Thoughts? Just don't want to hook up backwards!!!
thanks!!!
2007 Dodge RAM 2500 4x4 QC with the 5.9L CTD
2007 S&S Montana Bitterroot 9FBSC
2oldman
Winchester WA
Posted: 06/28/11 09:06pm Link  |  Print  |  Notify Moderator
Dang I wish you guys would take a picture before unhooking your batteries!
Battery polarity
Fire Instructor
Upstate (Albany) NY Area
Posted: 06/28/11 09:09pm Link  |  Print  |  Notify Moderator
Sounds like the white would be the ground. Easy enough to check with a simple ohm meter. Before installing the battery, set your multi-meter on ohms, touch one probe to the white terminal, and the other to the frame (chose a scratch, where there is no paint). If the needle jumps up, you have continuity, and that confirms the ground.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
"If everyone is thinking alike, then someone isn't thinking!" General George S. Patton
vern96
Washington State
Posted: 06/28/11 09:14pm Link  |  Print  |  Notify Moderator
is that the frame of the truck, or the camper?
Thanks for your reply!
Fire Instructor
Posted: 06/28/11 09:24pm Link  |  Print  |  Notify Moderator
The frame of the camper. You need to complete the circuit, and the camper chasis is the ground.
BTW - Once you confirm which is ground, it gets conected to the "-" terminal on the battery.
vern96
Washington State
Posted: 06/28/11 09:32pm Link  |  Print  |  Notify Moderator
thank you kindly fireman!
wnjj
Cornelius, Oregon
Posted: 06/28/11 09:50pm Link  |  Print  |  Notify Moderator
Or you can plug the camper into shore power and test across the leads for 13-14V. This way you don't have to worry about finding a good frame ground. Obviously be sure the leads are kept apart when you plug in. If you have it backward you'll read a negative number.
big dave
Soldotna, Alaska, USA
Posted: 06/28/11 11:48pm Link  |  Print  |  Notify Moderator
Just follow the white cable to see where it goes. Usually the cable is grounded within about 24" of the battery.
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
