RV.Net Open Roads Forum: Tech Issues: Onan 5500 won't start
 > Onan 5500 won't start
Medicine_Man
Lakeland, Fl 33803
Posted: 06/29/11 09:08am Link  |  Print  |  Notify Moderator
Help! My Onan 5500 (gas) won't start. With a shot of starting fluid, used very sparingly, it runs for just a second.
Loosened the carb bowl drain and nothing comes out. I suspect the float needle is stuck.
Any quick fixes? Sure hate to have to pull it out.
It ran 2 months ago.
2006 Gulf Stream Endura 6316
2007 Kar Kaddy SS
2008 Toy. Highlander Sport
2006, From Cent. Fl to Cent. Fl, by way of Alaska, 109 days & 14,947 miles
2010, From Cent. Fl to Cent. Fl, by way of Alaska, California, Washington, D.C. 97 days & 13,076 miles.
TAS
Baton Rouge, La
Posted: 06/29/11 09:31am Link  |  Print  |  Notify Moderator
Pull the fuel supply line first and make sure you have fuel to the carb. If you do, you're gonna have to pull it.
Todd
12 F-350 4x4 CC DRW
07 Dodge 2500, 4x4, CTD, 6spd (sold)
94 Harley FLSTC
98 TJ w/ a few mods
08 Fuzion 302
01 Rockwood 8292s (gone to a new home)
84 Jayco pop up (Sold but not frogotten)
Big Katuna
Deland, FL
Posted: 06/29/11 09:48am Link  |  Print  |  Notify Moderator
Its easy to pull the carb. I took mine off in a campground.
My Kharma ran over my Dogma.
RCM 97
home
Posted: 06/29/11 10:44am Link  |  Print  |  Notify Moderator
If you have checked all the normal engine problems
fuel to carb
spark at plugs
fuel not stale and carb not dirty
then check for voltage at the output of the gen and oil pressure sender(under oil filter)
many of the emerald and marquis gens need oil press and gen output to run
BEVAR
Lake Worth, FL
Posted: 06/29/11 10:47am Link  |  Print  |  Notify Moderator
How much gas in in the main tank?
B
Medicine_Man
Lakeland, Fl 33803
Posted: 06/29/11 12:32pm Link  |  Print  |  Notify Moderator
3/4 tank of fuel. Could air possibly unstick the needle?
The only problem I see is the carb bowl is dry.
Once I figure out how to remove the air cleaner box I can get to it.
* This post was edited 06/29/11 12:55pm by Medicine_Man *
sum1
So-Cal
Posted: 07/02/11 09:48pm Link  |  Print  |  Notify Moderator
Could damage it. As TCS aand RCM suggested, verify fuel through the line.
pacearrow96
Arnold,MO
Posted: 07/07/11 11:43am Link  |  Print  |  Notify Moderator
Sounds like what mine did last summer. The electric fuel pump for the generator was bad. After installing a new one it starts and runs like a dream.
* This post was edited 07/07/11 11:49am by pacearrow96 *
Jim E.
'96 Pace Arrow Vision 33L
'95 P30/32 chassis
'96 Tracker 4dr 4WD toad
"Don't tell me I can't do it, just tell me it won't be easy."
"If they don't make what I want I'll make my own."
jy
south east mich.
Posted: 07/07/11 01:15pm Link  |  Print  |  Notify Moderator
I have an Onan 5500 in a 99 MH.It has an electric fuel pump.A few years ago it wouldn't start.Found a broken wire to the fuel pump.spliced it back together,no problems since.
99 Coachmen 322QB, Ford V10,18 foot Load King open trailer, 2007 Mustang GT Toad, Gibson exhaust,Royal Purple lubricants.Recently retired and planning on doing more RV'ing.
