RV.Net Open Roads Forum: It's official...you cant tow that heavy up here.
Search only in Tow Vehicles
 > It's official...you cant tow that heavy up here.
Page of 8
MadMav
Colorado Springs, CO
Posted: 06/29/11 01:25pm Link  |  Print  |  Notify Moderator
I've been preaching this for a few years now.
Ford towing guide, last page...
High Altitude Operation
Gasoline engines lose power by 3-4% per 1,000 ft.
elevation. To maintain performance, reduce GVWs and
GCWs by 2% per 1,000 ft. elevation.
So, at 6000ft altitude, the 2010 F150 with the 5.4l is producing about 236hp instead of the 310 it would make at sea level. Thus making the maximum recommended GCVW at 15048lb instead of 17100lbs.
I just used Ford as the example as I was already on thier website. Same applies for Dodge, Chevy and Yugos.
Interesting fact: Turbo engines only lose power at 1/2 the rate of naturally aspirated engines as elevation increases. So at that rate, reduce GVWs and GCWs by 1% per 1,000 ft. elevation
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
ib516
Way up north eh
Posted: 06/29/11 01:34pm Link  |  Print  |  Notify Moderator
Interesting.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
kmfvfr
Las Vegas
Posted: 06/29/11 01:37pm Link  |  Print  |  Notify Moderator
Saw that a while back on the Ford website. My wife and I decided to follow that rule and now when we travel the 17 mile 6,000 ft elevation change to one of our summer getaway campgrounds, she rides in the back of the truck and tosses firewood out as we climb so we can compensate for power loss. [emoticon]
2008 Pacific Coachworks Tango 276 RBS
2007 Toyota Tundra TRD 5.7L ">
Prodigy Brake Controller
Yamaha EF2400iS Generator
Yamaha FJR1300
MadMav
Posted: 06/29/11 01:38pm Link  |  Print  |  Notify Moderator
As long as after you set up camp, you go back for the wood. [emoticon]
Mav
kmfvfr
Las Vegas
Posted: 06/29/11 01:43pm Link  |  Print  |  Notify Moderator
Mav
Better yet, have her drive the SUV, haul the wood and 5 gallon jugs of water to fill the fresh tank when we get there!!
Or get a diesel. But then I have to get one of each brand to satisfy all readers of this forum. [emoticon]
Burp
St. George's Island, MD
Posted: 06/29/11 01:50pm Link  |  Print  |  Notify Moderator
Is that the wood you should not be bringing into a camp site? Ya know, the one with illegal alien bugs. [emoticon]
When you fly small airplanes you have to take this into account to see if you can get off the ground again at high altitude airports. You also need to take into consideration the temperature. For example: If you are at Big Bear airport in CA (6700') and the temp is 100 degrees outside (this happens), the air is as thin as being at a 10,000' airport. The same would hold true for any normally asperated engine.
2007 Winnebago Voyage 33V (Workhorse, W20)
2008 Suzuki S83 (VS1400)
Me, the Wife ">, Sarah ">
Places we have camped in an RV
Yahooligan
Illinois
Posted: 06/29/11 01:51pm Link  |  Print  |  Notify Moderator
Naw, just put a Cummins backed by an Allison into a Ford, then you'll be covered. [emoticon]
Hogan & Clan
bldrbuck
one or the other
Posted: 06/29/11 02:32pm Link  |  Print  |  Notify Moderator
Why would you quote gasoline specs and call out a diesel?
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 35' King of the Road 5er, 192 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 2 Trogan T105 Batteries, Me, my wife and 2 maltize furkids.
MadMav
Posted: 06/29/11 02:37pm Link  |  Print  |  Notify Moderator
I never called out a diesel. [emoticon]
Mav
bldrbuck
one or the other
Posted: 06/29/11 02:42pm Link  |  Print  |  Notify Moderator
Sorry read 6.4 instead of 5.4
Page of 8
