RV.Net Open Roads Forum: Tech Issues: Water line leak at connection
 > Water line leak at connection
SpartanMan
Michigan
Posted: 07/13/11 06:10pm Link  |  Print  |  Notify Moderator
I've been checking everything on the trailer today. While I was running the water, it sprung a leak shooting water!! I located the leak easily. It was underneath the bed at a connection point. Water was shooting out from the connection shown. It appears the tubing came separated from the cone end which pulled out from the screw connector. I tried to simply place the cone end back on the tubing and screw it back in place. Worked for a short period of time until another gyser shot out! Any suggestions on how to cure this problem.
Old-Biscuit
Across the USA
Posted: 07/13/11 06:38pm Link  |  Print  |  Notify Moderator
If that is 1/2 PEX go to Home Depot and check out sharkbite fittings....they snap on and will not come back off (without special $2 tool) and do not leak. They are expensive but work!
Other fittings available also.....anything but them compression ones.
I hate compression fittings for that reason........If I have them, I replace them ALL.
anconn
Qualicum Beach, B.C. Canada
Posted: 07/13/11 09:00pm Link  |  Print  |  Notify Moderator
I had some flexible white hose in and around my water pump and outside fittings.(It was used so it bebt easily) I replaced it all with pex fittings and used 90's insted of bending hose. It is way less troub;e now without small leaks
2002 Seabreeze 34' MH
2005 Jeep Liberty
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/13/11 06:50pm Link  |  Print  |  Notify Moderator
There's supposed to be a toothed metal spring ring that slips on the tubing before the compression cone is pushed on. The ring grabs the tubing and keeps it from backing out when the nut is tightened. Any hardware store that carries "Quest" brand fittings should have the rings. They look sort of like lock washers. Just make sure you get the right size. I agree with Old-Biscuit though, I like Sharkbite, Watts, or SeaTech push-on fittings better.
Quest compression rings
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
SpartanMan
Michigan
Posted: 07/13/11 07:16pm Link  |  Print  |  Notify Moderator
Thank you all. I will be going to the hardware store tomorrow.
