RV.Net Open Roads Forum: Toy Haulers: Graphic Sticker Removal, How hard to do?
Search only in Toy Haulers
 > Graphic Sticker Removal, How hard to do?
juzplanekrazy
Riverside Ca
Posted: 07/19/11 02:00pm Link  |  Print  |  Notify Moderator
The stickers on my KZ New Vision are looking pretty sad. How hard are they to remove and wheres a good place to have new ones made and installed?
Thanks for any help.
Joe
2008 Ford F-350 4x4 Dually
2007 38' KZ New Vision Toy Hauler
Pullrite Super5th
jauguston
Bellingham, WA
Posted: 07/19/11 02:34pm Link  |  Print  |  Notify Moderator
There is a device called a decal eraser that is a wheel you put in a drill or a slow speed air tool. It is made of a eraser type material and is available at auto parts stores that cater to the auto body shop trade. Used by most all the body shops. I used it to remove remove decals and it worked pretty slick. Just be gentle and don't get the surface you are working on hot with too heavy a hand.There will be a shadow where the decals were.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Norcalrockhunter
NORCAL
Posted: 07/19/11 03:50pm Link  |  Print  |  Notify Moderator
We use them all the time here at our body shop they work pretty well if you take your time
if you need the part number for it PM me and I'll get it for you
gkall
Michigan
Posted: 07/19/11 04:08pm Link  |  Print  |  Notify Moderator
Try a hair dryer.
tjar66
Camarillo CA
Posted: 07/19/11 04:44pm Link  |  Print  |  Notify Moderator
Once you get them off you can order new from the factory or have custom made decals at pretty much any sign shop.
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
broccoli2
SoCal
Posted: 07/19/11 06:31pm Link  |  Print  |  Notify Moderator
Don't try the hair dryer.
2008 Bounder 35E F53
2007 WW FSC3200 (Sadly it's now sold)
2007 F350 4X4
2008 Yamaha Rhino Sports Edition
2008 Yamaha WR450f
2006 Honda Crf250X
1946 CJ2a Frame off
1974 CJ5
gpshemi
Lapeer, Michigan
Posted: 07/20/11 06:16am Link  |  Print  |  Notify Moderator
Forget the stickers...get a body shop to paint them back on.
GPSHEMI
06' 3500 Dodge Ram Megacab 4x4 w/ bombed 5.9L
18K Pullrite SuperGlide w/super rails
2010 Heartland Cyclone 3612
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/20/11 07:09am Link  |  Print  |  Notify Moderator
gkall wrote:
Try a hair dryer.
Hair dryer usually works great for removing vinyl stickers on metal siding or car bodies. Just don't focus too much heat in one place for too long or it can damage the paint.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
shagan77
Ozarks
Posted: 07/20/11 07:12am Link  |  Print  |  Notify Moderator
Same principle for removing the dealer advertising decals? (88% turning radius, blah, blah, blah)
2013 Sierra Denali 3500 Duramax\Dually
2011 Cyclone 3950 HD
2009 Harley Davidson Ultra Classic
2011 Can-Am Spyder RT-S Limited (DW's)
Usually a keg of beer....
ecoast
NW NJ's Highlands
Posted: 07/20/11 07:26am Link  |  Print  |  Notify Moderator
start with a heat gun; get as much to peel as possible.
Then use the 3M Stripe/adhesive removal tool as mentioned above...I use a high speed to get decals off.
Follow up w/ 3M adhesive remover #08904 or 'goo gone'
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
