DSeckt
Cedar Point , Northern Ohio
Delete
edited 07/19/11 05:56pm by DSeckt *
06 Ford F350 Dually/ Crew/ PS / SB
Lance 820.......
DSeckt
Was wondering why there was Styrofoam chunks laying in the cabnet..
ScottG
Bothell Wa.
That just plain sucks. Can you just replace the tank itself?
Scott, Grace and Wesly
H0NDA eu2000i
bobndot
NY
ok.
FYI or anyone else winterizing : When you winterize you have to close the inlet valve ( by-pass valve ) to the water heater before you start pumping the pink stuff by using that tag end of hose into the rv anti-freeze bottle. The campers water pump is used to do this and the pump gets protected as well.
If you don't close the by-pass valve to the water heater you will fill the water heater with 6 gals. of rv anti-freeze.
Its ok to have a little bit of water in the bottom of the water heater . It will freeze at the bottom and not harm anything. Its basically a thermos bottle , only more expensive.
bobndot
NY
Is that hose the tag end of the winterize set up ? Isn't that the hose that goes into the bottle of rv anti-freeze , to pump it thru the system when winterizing ? The blue decal says , "winterize" .
DSeckt
Yes it is. Wife remembered that about 5 minutes after I posted... Just can't figure out why the hot water tank blew up sitting on Galveston Island, Tx all winter...
Artum Snowbird
Campbell River, B.C., Canada
I did everything right, closed the input valve, opened the bypass valve, drained the hot water tank and left it with the drain plug removed, filled the unit with pink, and in the spring when I went to clean it out the check valve on the output of the hot water tank had lost it's seal. The pink in the lines went through the output of the HWT in reverse, and dumped pink into the HWT and out the drain plug.
It took about five or six full fills and flushes before I could think the HWT didn't have any pink left in it.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
Dennis&JoAnn
Security, Co
DSeckt,
I just went thru the same thing this spring. I remembered to close the by-pass when I winterized, just forgot to drain the fresh water out of the tank. I "noticed" the problem when I filled up for our first trip out this spring. I guess the good news is that the water heater is fairly easy to replace. Best of luck with the replacement!
Dennis
