Lots of Stuff
WA. USA
I'm rather proud of these mods.
Frist is my cable wobbel stopper.
I replaced the lowest jack bolt with an eye bolt then frabricated cables and S hooks to connect them.
Works well with camper off truck.
However the cables must be removed to load the camper.
Next I must give credit to "sleepy" as he gave me the idea of using Unistrut. He used it for repairing sag under his slide as I remember.
My camper dosen't have a slide but my hold down runs right across the fuel door making fueling harder.
Using Unistrut I can move the hold down mounting point aft untill it clears the fuel door. Note hole dirlled in Unistrut.
The Unistrut is held on using the same mounting bolts that hold the hold down tabs on my Lance. Unistrut is 8 feet long.
Next a light came on and I had these made at a local welding shop.
No welding but they could bend 1/4 inch thick steel plate and cut it to size for me. Just as they came from the welding shop.
Notice the old Lance tie down tabs on my bench, Unistrut replaced them. Also my cardboard pattern.
Here they are painted (the only color I had) and installed. Will be painted white in the future.
Note the fuel door clears without removing the Fast Gun.
One of my last tie downs in still in Los Angeles because I forgot it after refueling.
This picture shows how they are mounted to the Unisrtut. Bolts and Unistrut T nuts.
Here is the camper off the truck. Don't need the cable wobble stoppers any more.
Plus I don't think the jack mounting lags will elongate there holes anymore.
One more idea. Look at this picture. Release the Fast Gun swivel it up alongside the Unistrut drill a hole just a little aft of the bottom anchor point. Install the Fast Gun in both holes. Then you could store the fast gun right on the Unistrut. Could even be locked.
Sorry I haven't done it yet so a little imagination is required.
Will try to answer any questions.
Finaly finished mods, here are more pictures.
Fast Guns holding the camper on. Notice the locks.
Fast Guns in storage position. Notice they still can be locked.
Close up showing holes in unistrut to hold Fast Gun in storage position.
Repainted the guessets white. At this point I don't think I will paint the unistrut. Added another clamp to the guessets because it looks better.
Very happy with the mods so far!
last
edited 10/05/11 04:40pm by Lots of Stuff *
View edit history
DG
03 Chevy Silverado Regular Cab 2500HD 4X4 Duramax
04 Lance Lite 915
covered wagon
Great ideas and workmanship. Your jacks are not going to fold like that.
Paoli
Quesnel BC
You have done a nice job!
PapPappy
Wilmington, NC
Tire looks a bit low in the bottom picture
Great ideas and workmanship!
Thanks for posting the pictures.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
sleepy
Oak Ridge,Tennessee
nice... all new ideas... well done
sleepy
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
bobndot
NY
Nice job , great ideas . When i begin to wobble when i walk, can i call you ? Maybe you should start doing hips .
SoCalDesertRider
SanDiego, CA, USA
Cool ideas.
I agree that tire does look low.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Camper_Jeff_&_Kelli
Seattle
I like innovation.
I like the front jack angle gusseting.
I’m not certain the side to side sway in front is handled as well by these as for instance your original crossed cables or the Tork Lift brace things they are making for side sway when free standing now. It looks like your front to back is very strong now.
Good thinking and job.
J&K
Camper Jeff and Kelli's Blog!
Dan L
MPLS, MN US
Nice job.
I also like your thinking and inovation.
But keep the cables, while the new brackets and unistrut add lots of for/aft strength, they add little sideways when compared to the cables.
And did I say I really like those cables.
I need to make a set for mine.
Thanks for posting,
Dan
sabconsulting
High Wycombe, UK
Very nice - I really like the cable wobble-stoppers - great idea.
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'92 Suzuki Samurai 4x4 1.6
'09 Fiat Panda 1.2
'10 Citroen DS3 1.6 turbo
