RV.Net Open Roads Forum: need help with 454 belts! Its Hot!
 > need help with 454 belts! Its Hot!
JGorski73
Stevensville, Maryland
Posted: 07/21/11 06:54am Link  |  Print  |  Notify Moderator
Im not sure if I have enough belts on my AC Compressor. It has 2 grooves but I only have the belt closest to the compressor. It squeals while the compressor is engaged but am not sure if it is tight enough or needs a belt on the outer pulley. Am I missing a belt?
JGorski73
Posted: 07/21/11 07:03am Link  |  Print  |  Notify Moderator
oops I forgot to say it is a 1990 fleetwood southwind on the p30 chasis...
jmerritt
Evendale, Ohio
Posted: 07/21/11 08:47am Link  |  Print  |  Notify Moderator
A squealing belt indicates that it is either too loose or that maybe some oil or coolant is on the pulley causing it to slip. Also, dpending on the size of the belt that you have on there, if it is too small that could also be your problem. The design probably requires both belts or GM wouldn't have built it that way.
John
1988 Fleetwood Limited 37' MH
falconbrother
North Carolina
Posted: 07/21/11 08:55am Link  |  Print  |  Notify Moderator
I have a 1990 P-30, 454. If memory serves there is just one belt on there. If I wait till I'm running 65 and turn the AC on it sometimes squeeks. If I turn it on at idle it seems like it doesn't. Go figure? This time of year I run the generator and the roof AC. The dash AC does little to keep the RV cool on 100 degree days. In fact, when it's really hot. I run both and it still stays warmer than I would like. It's a lot of space to cool down. Especially if it's been sitting in the sun and is good and hot before I start. This time of year we try to get or traveling out of the way before it gets too hot out.
JGorski73
Posted: 07/21/11 10:00am Link  |  Print  |  Notify Moderator
I'm with you I think it is only one also. I talked to some local knowledgeable people and they agree. I just need to tighten. It some. I havent had my generator running since I bought her. I know the muffler is broken off of it. It would be ok to run while moving but I'm sure it would be loud as Hell. Plus I'm sure it would eat a lot of fuel? Do you know how much mpg's you get just running with no gen.?
falconbrother
North Carolina
Posted: 07/21/11 12:00pm Link  |  Print  |  Notify Moderator
On average the Onan 4000 uses like, .6 gallons an hour (depends on how hard it's working). That's not bad at all in my book and has little impact on overall gas mileage considering that when I'm pulling my toad I get 9.5 mpg (average). I would get that muffler fixed and run that sucker. I've never had to deal with this but, I have a muffler guy that can fix anything exhaust related. I'll bet a local muffler shop could build you a muffler, and install it, cheaper than you could buy a new one. In this heat the dash air wont accomplish much without help from the roof air.
Gale Hawkins
Murray, KY
Posted: 07/21/11 12:42pm Link  |  Print  |  Notify Moderator
3x of only being one belt on our 1992 P30. Sometimes gets a squeal on start up in hot temps. Have gotten on start up and had to turn off the AC and try in a couple minutes. We redid our dash AC in the drive by flushing the evaporator and condenser, replacing the dryer and trinary switch and removing and replacing R-12 O rings with green ones for R-134a. Not sure they help but were only $10 and I was already taking things apart.
It cools really well and over time will put out 42F air temp. We turn it off if outside temps get 5F less than inside temps.
Macrosill
NY
Posted: 07/21/11 09:13pm Link  |  Print  |  Notify Moderator
On my rig the A/C belt is also used on the power steering pump. There are 2 belts on the power steering pump. Make sure the belt on the PS pump that does not come up to the A/C is tight before you tighten the A/C belt. If not the A/C belt will be tight but the other belt on the PS pump will be loose. I found out the hard way.
* This post was edited 07/21/11 09:24pm by Macrosill *
Thanks,
Brian
TT = 2007 Jayco Jay Flight 27bh
TV = 2003 Chevrolet Suburban
BULLETLS1
Guatemala, C.A. (NOT Dakotas, Wyoming, Iowa...)
Posted: 07/21/11 09:24pm Link  |  Print  |  Notify Moderator
Macrosill wrote:
On my rig the A/C belt is also used on the power steering pump. There are 2 belts on the power steering pump. Make sure the belt on the PS pump that does not come up to the A/C is tight before you tighten the A?C belt. If not the A?C belt will be tight but the other belt on the PS pump will be loose. I found out the hard way.
remember that this arangement of the power source for the PS pump, is that the ps pump ALSO powers the hydroboster for the brakes soooooo if one belt fails (or its bearings) there is another power source (diferent) you are not left w/NO brakes!!!!
I I HAVE A DATE WITH ETERNITY, AND I DON“T WANT TO BE LATE!
bsinmich
Holland, MI
Posted: 07/22/11 12:28am Link  |  Print  |  Notify Moderator
If you run the generator and roof air with the dash air off you may not notice much difference in fuel consumption. The 454 not having to turn a compressor will have less load and give a slight improvement in MPG.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
