RV.Net Open Roads Forum: Tent Camping: Pulling Tent Stakes?
Search only in Tent Camping
Open Roads Forum  >  Tent Camping
 > Pulling Tent Stakes?
Chuck&Gail
In the Colorado Mountains
Posted: 07/24/11 05:11pm Link  |  Print  |  Notify Moderator
I used those stakes for many years and very rarely ever broke one. Find a rope, and tie a slip knot in one end (a hangmans knot worked great for me). Put a handle of some kind on the other end (I found a piece of closet rod with a hole in the center for the rope worked great). To remove a stake, slide the slip knot over the stake and tighten UNDER the green piece so you do not pull on the plastic tip. Now just pull up on the handle. Try to pull stake straight out. Note the rope can be twisted on the handle to make it shorter as needed.
Once you get the length you like, you can cut off excess rope. I used the same rope for over ten years to do that.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
hikenhunter
where ever
Posted: 07/24/11 08:42pm Link  |  Print  |  Notify Moderator
don't buy the staskes with the plastic, instead buy thev large nails used to hold landscape ties together. Slide the stakes through a large washer then when you want to pull them you can use your stake puller or a claw hammer.
Francesca Knowles
Port Hadlock, Washington
Posted: 07/28/11 08:55pm Link  |  Print  |  Notify Moderator
I've had one of these in my kit for years- it's a great all-around camp tool.
Makes pulling stakes real easy- the handle's about 2 feet long, so you don't have to bend over much to use it!
http://www.amazon.com/gp/product/B004FOV........01&pf_rd_i=B0055IXOIM&pf_rd_m=ATVPDKIKX0
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
TN_CAMPER
Knoxville, Tennessee
Posted: 07/30/11 11:15am Link  |  Print  |  Notify Moderator
I grab a piece of rope and wrap it around the tent stake, then yank it out. Helps if the tent stake isn't sunk too far down in to the ground or if it has some sort of head or hole in it. No special tools needed (i already carry too much stuff as it is )
big whitey
raleigh,nc
Posted: 08/01/11 06:50pm Link  |  Print  |  Notify Moderator
K Charles wrote:
When we had a tent we used a claw hammer to remove those pegs
X2
'tiredTeacher
Richmond, VA
Posted: 08/02/11 09:27am Link  |  Print  |  Notify Moderator
Claw hammer or, as stated before, a small wrecking bar. I've used both. I love those stakes and won't go back to anything else (until I hit the beach, but that's a whole 'nother issue).
Teach
Wright and Penny
2010 Tundra 4X4
2005 Starcraft 2107
1995 Sunline Solaris T-2653
"Life is a cruel teacher. She gives the test first; the lesson then follows."
RoyB
King George, VA
Posted: 08/02/11 01:28pm Link  |  Print  |  Notify Moderator
I use just a regular claw hammer - lay a short board of rock next to it and grab the top of the stake with claw and pull down... Usually comes right up.
I carry all of "tent" stakes and claw hammer is same tote box. I always drive the stakes in at an angle for more strength so pull them out with that angle...
Here lately I have been using the three-inch round 18-inch long earth augers with a short loop on top. Use a tool extension as handle and they just screw into the ground with ease. When you unscrew them to take them out doesnt leave any mess or holes in the ground.. They will hold alot more of strength than the tent stakes will hold... Got mine off eaby but noticed PEPBOYS carries them where the generators and portable garages are located.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Gene&Ginny
North Kingstown, RI
Posted: 08/05/11 06:44pm Link  |  Print  |  Notify Moderator
I use a pair of slip joint pliers. Grab the head of the stake and twist until loose then pull out. Small enough to bundle with the stakes.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Tyme4ToPlay
SW Indiana
Posted: 08/05/11 07:13pm Link  |  Print  |  Notify Moderator
I haven't been back out since I posted this question, but I have some replacement stakes for the ones that bent, got the washers and a claw hammer and some rope. Should have all the bases covered.
oldbeek
lancaster CA
Posted: 08/18/11 11:59pm Link  |  Print  |  Notify Moderator
Desert tenters use 12 inch concrete form stakes with a flat welded on top. also 3 pound sledge hammer. Beat them on the side to lossen them up. Use 24 inch for sand camping. or use a pop-up with no stakes.
1994 27sl Alpenlite, 2001 Dodge Cummins auto 3.54 stock
