RV.Net Open Roads Forum: how much elect. does your rv refrigerator use?
 > how much elect. does your rv refrigerator use?
oldbeek
lancaster CA
Posted: 07/24/11 03:58pm Link  |  Print  |  Notify Moderator
I was doing an audit of how much AC each appliance used at my home. I bought a Kill-a-watt meter to do the audit. When I came to my plugged in RV, it used 5kw per day. In So. Calif. that is $.75 per day. Upon further investigation, I found the frig was using over 4kw per day. And the inverter was using the remainder. My 21 cu ft frig in my house uses 2.1 kw and my 14 cu ft freezer uses 1.6kw/ day.
1994 27sl Alpenlite with many mods, 2001 Dodge Cummins 2x4 3.54 Auto trans built shift kit and 2nd gear lock up mod. Mojave Green billet, triple disc low stall torque converter. Gauges and raptor 3/8inch fuel system. 12.5 mpg avg
pianotuna
Regina, SK, Canada
Posted: 07/24/11 04:10pm Link  |  Print  |  Notify Moderator
Hi,
I've done some testing on my Dometic Fridge. It takes 3.7 kwh to cool it down. It takes 4.8 kwh to run it for 24 hours. The duty cycle is 2/3.
I've added fans and have not had a chance to repeat the tests above with them running.
If you are paying for the electricity it may be cheaper to run on propane. If you are not--then go for it!
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
ScottG
Bothell Wa.
Posted: 07/24/11 04:27pm Link  |  Print  |  Notify Moderator
Here in Wa. state, it costs me $5 a month to keep the fridge on.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
mena661
Posted: 07/24/11 04:32pm Link  |  Print  |  Notify Moderator
Do you live in your RV? I just turn my RV fridge off when I'm at home.
Trojan L16 6V's 740 Amp-hours
red31
Bryan
Posted: 07/24/11 04:50pm Link  |  Print  |  Notify Moderator
One of the smallest Dometic 1.9 cuft compact fridges is rated 115 watt AC.
Golden_HVAC
Fulltime, CA, USA
Posted: 07/24/11 07:29pm Link  |  Print  |  Notify Moderator
Hi,
I would leave the refrigerator off when not in use. THey are expensive to run it when not getting ready to go camping. Like stated above, 4.8 KW a day is not unusual. Your home electric refrigerator is much more energy efficient.
The problem is that when boondocking, it is nearly impossible to beat the low wattage used by a propane refrigerator on gas. They only use about 50 watts a day when on gas.
If you unplug the inverter for a long time, expect the batteries to go dead in about a week. The propane and carbon monoxide leak detectors use about 1.6 amp hours per hour, and will use up 35 - 40 AH per day, or 220 in a week.
Fred.
Gale Hawkins
Murray, KY
Posted: 07/24/11 07:54pm Link  |  Print  |  Notify Moderator
A frig with a 325 watt heating element in 24 hours with a 100% duty cycle would use about 7.8 KW.
Yes per Cu. Ft. a RV frig can have an energy cost of about 1200% more than a new home model.
