SoCalDesertRider
SanDiego, CA, USA
Diamo wheels? I have not heard of those. Do you mean Diamond Racing Wheels?
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
jimh425
Western WA
SoCalDesertRider, it sounds like your 18 option is not readily available although it is theoretically possible.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
Bigfootchevy
Bancroft, Ontario, Canada
I don't think changing the 19.5's G's to F's is going to make much difference.
Paul
SoCalDesertRider
SanDiego, CA, USA
jimh425 wrote: SoCalDesertRider, it sounds like your 18 option is not readily available although it is theoretically possible. Interestingly, not long after posting here earlier that Diamond dropped the ball and never made the wheels for me, the owner of Diamond called my house to say he was ready to start making the wheels and needed some clarification on sizing/fitment specs before he builds them. Maybe he reads the forum??
Wheelholder
jacksonville, fl
I have some 285/75-16's on my silverado. Rated for 3750# (nitto terra grapplers) I also found some alloy wheels made by gear that ae rated for 3750#. Makes me more comfortable with the weight of my Lance 830 on the rear axle.. I now have 7500# capacity instead of the 6084# of my oem wheels. 18 inch wheels would never fit under the silverado in the front.
2008 Silverado crew cab Duramax/Allison
2008 Lance 830
SoCalDesertRider
SanDiego, CA, USA
Wheelholder wrote: I have some 285/75-16's on my silverado. Rated for 3750# (nitto terra grapplers) I also found some alloy wheels made by gear that ae rated for 3750#. Makes me more comfortable with the weight of my Lance 830 on the rear axle.. I now have 7500# capacity instead of the 6084# of my oem wheels. 18 inch wheels would never fit under the silverado in the front. Who makes the wheels?
nkrantz
Farmington Hills Michigan
Any updates on the 18"s I have a AF 811s that sits on a 2010 ram with XD diesels that are rated for 3200 wraped in nitto 285s that are rated for 4000. just cracked a rim on a trip had to spend a couple of days in ohio getting rims. I say rims because I orderd a replacment and a full size spare. I really dont want to put 19.5s on the truck due to not being able to air down in sand and snow
AF 1140 2 optima yellow tops Honda eu3000 honda eu 2000 companion
2012 Ram 3500 DRW Roadmaster Sway Bar, Airbags, stableloads, superhitch, Buckstop bumper, carli lift, Alcoa's with 3970lb toyo AT's
kereams
Beaverton, OR
SoCalDesertRider wrote: jimh425 wrote: SoCalDesertRider, it sounds like your 18 option is not readily available although it is theoretically possible. Interestingly, not long after posting here earlier that Diamond dropped the ball and never made the wheels for me, the owner of Diamond called my house to say he was ready to start making the wheels and needed some clarification on sizing/fitment specs before he builds them. Maybe he reads the forum??
Let me know how long it takes them and how much they charge you.
2011 F350 SRW CC/LB/PSD, Supersway Stops, Firestone Airbags, Hellwig Big Wig Rear Sway, Rancho RS900XL shocks, 19.5" Hankook DH01 setup.
2012 Chalet Ascent S95R Camper
2011 Continental Cargo Talwind 7x12 DA Trailer (For the toys...)
rbcamping
san diego
Are you feeling the harshness in the rear or front? I have 19.5s and did not notice that much difference in the ride. I just noticed that there was a slight difference in the harshness on the initial impact. If you notice a bucking on the roads, its not caused by the tires, its the suspension. I would put some Sulastic rubber springs on it and that should soften the ride. Mine are going on next week.
https://www.sulastic.com
sirdrakejr
Las Vegas, Nevada
The biggest difference I noticed with using the 19.5" wheels/tires is due to the stiffer sidewalls, I feel every rut and track in the road. The truck feels more yawing than I ever did with the stock wheels/tires. I have learned to live with it but it was very unnerving at first.
Frank
