Need to replace my chassis starting battery on my 06 MH any recommendations appreciated.... Just replaced my 2 house deep cycles before this year. Thanks in advance
Bob/Marlene and Crystal(Golden Retriever)and sometimes Grandkids....
37' Alllego Bay dirts for racing/asphalt's for getting there
njdirt wrote: Need to replace my chassis starting battery on my 06 MH any recommendations appreciated.... Just replaced my 2 house deep cycles before this year. Thanks in advance
It really all depends on how much you want to spend. Any name brand lead-acid battery will probably serve you well as a starting battery. I like Interstates. If you want the very best, consider an Odyssey AGM. http://www.odysseybattery.com/ I use these in my motorcycle and classic '72 VW. They last forever and can sit for very long periods without loosing charge. I will probably replace my standard starting batteries with Odyssey's when they eventually fail and NEVER worry about the starting batteries again.
MartinDYN wrote: I did the same but got them from Pep Boys. They are Duracell 31's. $105 each.
got 31 series from autozone on thursday senior discount day for $89.00 plus taxes last march
But I doubt the OP has the cable set up for a 31 as they are usually for dual battery DP set up,s
