RV.Net Open Roads Forum: Winegard Trav'ler Satellite Install Tomorrow - Oh Boy!
 > Winegard Trav'ler Satellite Install Tomorrow - Oh Boy!
sailor53
Mesa, AZ
Posted: 07/29/11 05:55pm Link  |  Print  |  Notify Moderator
Bob Vaughn wrote:
Sailor 53,
Why not zip down to Camping World in Kississimmee and get a carryout by wingard and then all you have to do is just set it outside and it does the finding of the sat. all by itself....
The idea is not to have to set up anything outside.
DW Barbara for 15 yrs
08 Ford F350 Lariat, PSD 6.4L, Ext Cab, 4X4, Line-X, DrawTite Signature 18K hitch, RDS 40 gal. Tank/Tool Box Combo, Mor/ryde RS suspension, Garmin Nuvi 465T GPS
09 Montana 3000RK, Mor/Ryde suspension/pinbox, Spendide 2100XC W/D
sailor53
Mesa, AZ
Posted: 07/29/11 05:56pm Link  |  Print  |  Notify Moderator
enblethen wrote:
i would also sugest the Winegard Carry out. Advantage is the ability to move it around to avoid obstacles.
We are keeping the dish and tripod for those times.
RoyB
King George, VA
Posted: 07/29/11 06:39pm Link  |  Print  |  Notify Moderator
I know you have your heart set on the roof mount but I know of several folks that did just that and it seems like everytime they park at the camp sites they dont get a good view of the southern skies and the auto system doesnt pick it up. You always want to park the RV under trees to keep it cooling better. The portable vesion works just as well with nothing for you to do except sit it in the area where it can get a clear view of the southern skies. Of course another down side with the portable is you have to secure it somehow to keep it from growing legs...
Now it does work at alot of places on the roof but that is a real problem not working all the time. I'd say probably 25% of the time it wont work for you based on what my faily tells me that has one....
Also I am just going by hear-say here.... Too rich for me to own one... Maybe others on here will dime-in on their success of picking up the SAT signal...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
SCVJeff
Santa Clarita, CA.
Posted: 07/29/11 06:43pm Link  |  Print  |  Notify Moderator
There is a BIG difference between a Carryout and a Travler. 1st the Carryout is not, and never will be HD on DTV. 2nd, there is no substitute for gain, and the Carryout simply doesn't have the reflector, hence gain. Is that a bad thing?.. Depends on where you're watching from and through (rain, fog, trees, etc. Also, that dome is a magnet for moisture, another satellite killer. Ask anyone with a dome. Not good or bad. It is what it is..
Sailor: If you are installing it yourself, just be careful when handling and lifting the dish, because it moves at will and is ravenous on pinching fingers.
Jeff - WA6EQU
Monaco Montclair
Virginia
Posted: 07/29/11 06:56pm Link  |  Print  |  Notify Moderator
Waz thinking bout what was the best to get. Need some info on all the kinds. Thanks. Happy camping
Bob Vaughn
Seffner, Fl.
Posted: 07/29/11 05:57pm Link  |  Print  |  Notify Moderator
Oh...
OTTO
Western Washington/Gold Canyon, AZ
Posted: 07/29/11 11:34pm Link  |  Print  |  Notify Moderator
I have both the Traveler and a portable Slimline dish on tripod for those trees that get in the way. I installed the Traveler myself. First, have someone assist you getting it on the roof-it is heavy and awkward to handle. I allways over-engineer everything I do so I screwed and glued a 3/16" 24"X30" piece of aircraft grade aluminum on top of my aluminum roof-then mounted the Traveler on top of that..
It is truly a "one button touch" system. There is a Youtube video you can search that takes you through instalation.
http://www.youtube.com/watch?v=_03Jh2Qxgkk
kakampers
Fulltimer
Posted: 07/30/11 05:06am Link  |  Print  |  Notify Moderator
Same here...we also carry a portable slimline for those times when we're stuck under trees...we routinely ask to be out in the open, if available.
As to how well it works...the Trav'ler is pretty much flawless...turn it on and it does the rest. As long as there's no obstruction it WILL find and lock on to the sats. Hit the button when you're leaving and it stows itself...couldn't be simpler. In addition, we've been in 50 mph winds and get no digitizing at all.
You definitely will need two people to get it to the roof...the bugger IS heavy, but the install was pretty straight forward.
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
tom cav
orange co
Posted: 07/29/11 09:16pm Link  |  Print  |  Notify Moderator
when i installed mine ,i got a larger alum plate shaped
to my roof line ,alittle more stable in the dez winds. got the dish on sale /shiped 1300 ,also run all rg6 cables in to your rig ,i ran one to the basement so i can watch tv if i want
2007.5 cc,sb.ltz 4x4 d/a ,o9 eclipse stellar 34 lksg 2012 xp-4, 08 4seat rhino . yamaha 125 grizzly 125 breeze
sirdrakejr
Las Vegas, Nevada
Posted: 07/29/11 09:18pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to Technology Corner.
Frank
