RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: Crockpot help
Search only in Camp Cooks and Connoisseurs
mwaites
NC
Posted: 07/30/11 06:41am Link  |  Print  |  Notify Moderator
I wanted a Crockpot for Christmas. After my DD bought me one my hubby said it would run down the batteries. He's really smart but could he be wrong??? The crock is 6 qts, we have a Roadtrek with 2 12 volt batteries (besides the one under the hood, lol) and some kind of charger/inverter plus a generator. I want to be able to prepare my meal in the AM & then go sight seeing and have a ready meal in the evening. Any suggestions??? Thank you.
Mountain Mama
N. TX
Posted: 07/30/11 06:52am Link  |  Print  |  Notify Moderator
Are you boondocking with out electricity? If so, you may have a problem and there should be others who can offer advise, but it you're plugged in to electricity, you will not run down the battery.
2003 Holiday Rambler Alumascape 34RLT
I am still wayne_tw
everywhere
Posted: 07/30/11 07:09am Link  |  Print  |  Notify Moderator
My crockpot is 170 watts at 120 volts or 1.41 amps at 120 volts. That equals 14.1 amps at 12 volts. Using the crockpot on high for 5 hours on 12 volts would use 70.5 amps or about 1/3 of one typical RV battery. Since you have two RV batteries, I think your husband is wrong. Why not just try it out and see what happens; you could even try it out in the driveway where it really isn't an issue one way or the other. Assuming that you take the roadtrek sightseeing, the batteries will charge while you drive.
goreds2
OH H ..... EYE OH !
Posted: 07/30/11 07:19am Link  |  Print  |  Notify Moderator
Have you considered a 12 volt crock pot? (Click Here)
See Picture In My Profile
1990 Dodge XPLORER RV Van- Purchased 10/15/10
Chick Magnet !
* Sportsman GEN154 2000 Watt 80cc Portable Generator *
XM Satellite Radio since 12/25/2004
Sold my Class C 1976 Dodge TEC Motor Home 9/25/10
pianotuna
Regina, SK, Canada
Posted: 07/30/11 07:53am Link  |  Print  |  Notify Moderator
Hi,
What is the wattage on the slow cooker?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
rrupert
NW PA
Posted: 07/30/11 07:54am Link  |  Print  |  Notify Moderator
IMO, with either 120 volt or 12 volt crock pot you will come back to a cold meal and a dead battery unless you are hooked up to shore power. If you run the generator you could do it.
* This post was edited 07/30/11 08:06am by rrupert *
Rich and Joyce
2010 HiLo 2310H
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
mwaites
NC
Posted: 07/30/11 08:06am Link  |  Print  |  Notify Moderator
the wattage is 320.
KD4UPL
Swoope, VA
Posted: 07/30/11 08:11am Link  |  Print  |  Notify Moderator
If you leave a 320 watt crockpot hooked up thru an inverter it will draw around 33 amps from the batteries. If your 2 batteries are fairly typical group 27 12v deep cycle batteries they are about 100 Ah each. You really only want to use half of their capacity to maximize their life. This means you can only run the crockpot for 3 hours. However, their 100 Ah capacity is figured at being discharged over a 20 hour period. This means that discharging them over 3 hours will lessen their capacity. So, really, you could probably only run it for 2 hours.
To answer your question, no, you can't run a crock pot in an RV without being hooked to electricity or running a generator.
mwaites
NC
Posted: 07/30/11 08:22am Link  |  Print  |  Notify Moderator
Thanks everyone, I REALLY knew my hubby was right BUT I was hoping someone knew a trick to make it work.
MaverickBBD
Formerly of Bellingham, Wahington, U.S.A.
Posted: 07/30/11 09:48am Link  |  Print  |  Notify Moderator
As mentioned you will run down the batteries without shore power. One of the beauties of a crock pot is that you can use it going down the road. Put it in the sink and turn it on and have a hot meal when you arrive at your destination.
Tom, Cheryl & Blossom(coonhound mix)
'05 Winnebago Journey 36G w/Cat. C-7 350 hp Freightliner XC
AFE air filter, aero turbine muffler, 4 FSD Konis, ultra track bell crank and Safe-T-Plus
FMCA 397030
WIT 129107
