RV.Net Open Roads Forum: Truck Campers: Extension hitch critique
 > Extension hitch critique
Page of 6
Owyheedog
Weiser, Idaho
Posted: 07/31/11 09:09am Link  |  Print  |  Notify Moderator
My experience with a very similar setup, minus the chains... I flat towed my Jeep Wrangler for several years thinking that with virtually zero tongue weight I would never have any problems. That was true until the day that I managed to hit just the right bump at the right time at the right angle resulting in bending the extension so bad that we had to unhook the Jeep and my wife had to drive it all the way home. And this wasn't with wimpy materials either, I tried to bend the extension back into shape using my shop press and couldn't even budge it. It now lives in my scrap iron pile and a Super Hitch/Super Truss lives in it's place.
2001 Dodge 3500 DRW, 2010 Outfitter Apex 9.5, 99 Jeep TJ dragging behind.
Atchafalaya_man
Lafayette, Louisiana
Posted: 07/31/11 09:56am Link  |  Print  |  Notify Moderator
Your rig is far superior to many store-bought items available. Hitch it up and come by the house and pick me up.
bjbear
Cold Lake, AB, Can
Posted: 07/31/11 07:02pm Link  |  Print  |  Notify Moderator
Glad you related this story. It is a good example of dynamic loading and why it needs to be considered when working out the weight limits.
03 Dodge 3500 DRW
Edge, Pacbrake, Banks Air
ATS Billet Trans, Viscous drive Torque Conv.
08 Corsair Excella 1050 Camper, 200W solar
09 Blazer 20' Covered Trailer
Stehl Car Dolly (Toad 05 Mini Conv)
48 Willys CJ2A & 74 Jeep CJ5
JoeChiOhki
Sauvie Island, OR
Posted: 07/31/11 07:11pm Link  |  Print  |  Notify Moderator
This isn't a critique of what happened, I'm just figuring the physics in my head, but did you have any kind of supplemental braking module in your jeep (Blue ox, etc...)?
CB Channel 17 Redneck Express
bobndot
NY
Posted: 07/31/11 10:35am Link  |  Print  |  Notify Moderator
I don't mean to offend anyone here , some people offer good sound advice .
Being that you are not sure 'how to build ' this , why take the chance on not doing right. It might end being a liability for you. With a 6000# trailer, this is not exactly a lightweight combo. If an accident occurs,'you' are liable . It will cost you a lot more than $1500.00 than a Tork-lift super hitch would cost .
If you have a professional shop set you up , you shift the liability from 'you to them'. It's not always worth trying to save a relativily small amt. of money when it comes down to D.O.T specified hitches to be installed on motor vehicles that are used on public highways.
Shops that perfprm this type of work are D.O.T certified . This is done for a reason.
bka0721
Republic of Colorado
Posted: 07/31/11 10:55am Link  |  Print  |  Notify Moderator
This is certainly an accident waiting to happen. Test would be braking in a sweeping corner or going over a "speed bump" in a COSTCO parking lot. For me, I went the way we did when I was farming as a kid.
The back frame area and hitch base, on your truck, is positioned better than most with Truck Campers. Maybe you should consider approaching your hitch extension solution from a different perspective. This is what I have done and did back in the 70s, for our heavy hay wagons.
This is sage advice! All my work has been fine tuned and welded by a D.O.T. certified welder. I would not risk anything less. (My loaded trailer TARE Wt, is 4200 #)
Good luck and travel safely, my friends and family are out there on the roads you are towing on.
bryan
Reddog1
El Dorado, CA
Posted: 08/01/11 10:09am Link  |  Print  |  Notify Moderator
Owyheedog wrote:
My experience with a very similar setup, minus the chains...I flat towed my Jeep Wrangler for several years thinking that with virtually zero tongue weight I would never have any problems. That was true until the day that I managed to hit just the right bump at the right time at the right angle resulting in bending the extension so bad that we had to unhook the Jeep and my wife had to drive it all the way home. And this wasn't with wimpy materials either, I tried to bend the extension back into shape using my shop press and couldn't even budge it. It now lives in my scrap iron pile and a Super Hitch/Super Truss lives in it's place.
Not a fair comparison. I question you would have bent the original extension if it had the chains.
I would be uncomfortable with any extension over 18-inches, without the chains. But that is just me.
Does the Super Hitch/Super Truss have chains?
Wayne
bobndot
NY
Posted: 08/01/11 10:51am Link  |  Print  |  Notify Moderator
super hitch has chains .
superhitch
Reddog1
El Dorado, CA
Posted: 08/01/11 10:57am Link  |  Print  |  Notify Moderator
Thanks bobndot, I thought so, but was not sure.
Wayne
bjbear
Cold Lake, AB, Can
Posted: 07/31/11 09:10pm Link  |  Print  |  Notify Moderator
ticki2 wrote:
I would like to thank everyone for their thoughts and comments so far. I am still trying to digest much of it.
Clearification , the 4x4 tube/bumper is attached to the truck frame with side plates that come up along the outside of the frame and rap around the top of the frame . Each side is bolted to the side of the frame with 4 1/2" bolts , total of 8.
Some guidlines that I used was the Reese towbeast 41" extension which seemed to have the requiorments that I needed . The only difference between the two is mine has a 2" reciever with a 2" solid bar and theirs is a 2-1/2" reciever with 2-1/2" tube , and theirs has no chains.
Question on the chains . The working load on 5/16 30 grade is 1900#. Since that is the working load and not the breaking load I would think that it already has the 2x safety factor built in. I could also easily go to 1/2" chain and turnbuckles if that is the weak point.
Question on WD hitch. I don't understand what difference it makes if it is a 2" or 2-1/2" since it's relationship to the trailer would be the same and either is more than capable for the load.
I'm sure I am missing something here , my old brain is working overtime but some of the drastic reductions in capacities puzzle me.
PM sent
Page of 6
