RV.Net Open Roads Forum: Tech Issues: Duo-therm ac question
 > Duo-therm ac question
scarpi
Phoenix
Posted: 07/30/11 05:18pm Link  |  Print  |  Notify Moderator
My PW Excel has a Duo-therm 600 series roof top AC unit. I live in Phoenix where in the summer it gets hot as hell in the RV and that makes it hard to work on things in there. I've tried running the roof top AC with the RV plugged into the house outlet in my garage which is a standard 15 amp outlet. The AC unit blows the circuit breaker and shuts off even though the rv is the only thing plugged into that outlet. Does this AC unit draw more than 15 amps? I thought you could run the rooftop ac unit while plugged into a standard house outlet as long as nothing else is plugged into that outlet. Thanks for any info and sorry if this has been asked before. Don
scarpi
Phoenix
Posted: 07/30/11 05:47pm Link  |  Print  |  Notify Moderator
I forgot to mention that I have to use an extension cord to reach my 30 amp rv cord. The extension cord I use is a typical orange outdoor power tool extension cord and I use my 30 amp to 15 amp adaptor to plug it in. I recently read on line that I should be using a 10 gauge extension cord. Maybe that is the problem. I'll buy one and try it. Any thoughts?? Thanks again.
LarryJM
NoVa
Posted: 07/30/11 06:10pm Link  |  Print  |  Notify Moderator
According to THIS all the the Penguins A/C need a CB rated at 20A and the compressor running amps (12 to 12.4) plus the fan amp (3.3 to 3.5) exceed 15A and so there you have your answer. That along with using any extension cord only makes matters worse.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
scarpi
Phoenix
Posted: 07/30/11 07:54pm Link  |  Print  |  Notify Moderator
Thanks Larry. I think you're right. The best way would be to have an electrician run a 20 amp line into my garage. Then I will use a 12 or 10 gauge extension cord to plug my rv cord into.
whjco
Lexington, KY
Posted: 07/31/11 06:02pm Link  |  Print  |  Notify Moderator
If you're going to have an electrician put in a new circuit, why not go ahead and install a 30 amp circuits? It won't be that much more expensive.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
