RV.Net Open Roads Forum: Tow Vehicles: When to change injectors ???
Search only in Tow Vehicles
 > When to change injectors ???
ilvtravln
Calif.
Posted: 08/02/11 03:45pm Link  |  Print  |  Notify Moderator
My former tow vechile, (95 Ford F 250 PSD 7.3L) which I now use as a work truck turned 100K miles. Is there a point at which I should change the fuel injectors ? On the other hand the old saying "if it ain't broke don't fix it". It runs excellent, I put in injector cleaner once in awhile. Thanks
Art
Dave H M
IL
Posted: 08/02/11 04:20pm Link  |  Print  |  Notify Moderator
I would not even think if messing with injectors if the rattler is running fine. My F 250 (99) has 160K on the clock.
I have never heard of changing out injectors just for grins.
camping man
Central Fla.
Posted: 08/02/11 04:33pm Link  |  Print  |  Notify Moderator
You might get 300k out of them, don't worry about it.
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
Turtle n Peeps
California
Posted: 08/02/11 05:08pm Link  |  Print  |  Notify Moderator
PM for injectors is like PM for points. (anybody remember those?)
The second you start a new engine they start to degrade.
How much you let them is up to you. I changed mine out on my 6.5 at 100K. I only did it because they were like $25 bucks apiece and easy to do.
I would think they would still be in there at some of the injector prices I have seen for some of these common rails!!! [emoticon]
5 grand for a friend that just did his in his 04 Dmax!!! [emoticon] But then again he had no choice because he was making oil and it was not PM.
If your really concerned about it you can pull one and bench pattern test it to see what the pattern does. That is only a few bucks to do and the shop can tell you what shape the injector is in.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
naturist
Lynchburg, VA
Posted: 08/02/11 08:21pm Link  |  Print  |  Notify Moderator
I understand the injectors for my Jeep CRD are around $600 each. Not something I want to replace if I can help it.
720Deere
Maryland
Posted: 08/02/11 08:34pm Link  |  Print  |  Notify Moderator
A 7.3 will let you know long before they totally fail. A common indicator is hard starts and rough idle on a cold start. What usually fails is on the high pressure oil side so they will begin to stick when they are cold. Even then, they usually pick up and go as the engine temp rises. As long as you keep clean oil in the motor, I wouldn't worry about it for quite a while yet.
I've seen them go several hundred thousand miles and I've seen some that didn't make 80,000 miles before they started to act up. Usually people who go long intervals on cheap oil seem to have the most problems.
2011 Ford F-350 4X4 CC LB SRW 6.7
2013 Keystone Fuzion 315
B&W Companion Hitch
1 wife 2 kids and 1 dog
skipnchar
Topeka or somewhere else
Posted: 08/02/11 08:47pm Link  |  Print  |  Notify Moderator
Had 135,000 on my F150 and injectors were still performing like new. Shouldn't be any reason to change until they no longer do their job.
durallymax
Wisconsin
Posted: 08/03/11 06:50am Link  |  Print  |  Notify Moderator
Your f150 injectors don't run at over 20,000psi
5k for a dmax injector job? You got hosed.
Like its been said, they will let you know when they are going put. Injectors are a wear part.
pigbike
Posted: 08/03/11 07:33am Link  |  Print  |  Notify Moderator
How long do the injectors usually last in a late model Cummins 5.9?
hotpepperkid
Kingman AZ
Posted: 08/03/11 07:12pm Link  |  Print  |  Notify Moderator
So how much should an injector job cost for a Dmax
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS (31') 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
