RV.Net Open Roads Forum: Class A Motorhomes: GM 8.1 Exhaust Manifold gasket blown
 > GM 8.1 Exhaust Manifold gasket blown
MrDoneIt65
Golf Country NC
Posted: 08/03/11 08:28am Link  |  Print  |  Notify Moderator
I own a 2002 Southwind motorhome on a Workhorse Chassis. It now has approximately 30,000 mile on it. It has set mostly because of the Norcold and Workhorse Brake recalls over the last 4 years. I "roughed" it when I tent camped. I had No intentions of "roughing it" when I bought this motorhome.
Now the exhaust manifold has blown on the right side. I was wondering if anyone else experienced the same problem. I know the old 454 Chevy's use to do that but I would have thought GM would correct that problem in a new engine. Guess it will sit until I can find someone to fix it.
'02 Southwind 37U towing '05 Chevy Colorado with Blue Ox tow bar and Brake Buddy. 8100 GM/Workhorse Chassis. Retired UAW-GM.
ScottG
Bothell Wa.
Posted: 08/03/11 08:34am Link  |  Print  |  Notify Moderator
Is it the manifold gasket or the "doghnut" gasket between the manifold and the down pipe?
Scott, Grace and Wesly
H0NDA eu2000i
okgc
Southern Michigan
Posted: 08/03/11 02:31pm Link  |  Print  |  Notify Moderator
I doubt your 8.1 has a gasket, probably a broken stud or like mentioned the donut on the connector pipe.
X2
2010 Tiffin Allegro RED 36 QSA with Chevy HHR toad
2009 Chevy 2500HD CC 4x4 w/6.0 Vortec
Sundowner horse trailer
My hobby cars
1965 Chevy Impala SS 396
1964 Chevy Nova SS
sc3283
St Louis
Posted: 08/03/11 02:41pm Link  |  Print  |  Notify Moderator
This may help from my 25+ yrs of towing with 454s...once you make the repairs....change the thermostat to a 160 degree. I drove my last CC dually ( a 91) 14 yrs without a manifold problem/leak once doing that. Prior to the thermostat replacement, I had 5 manifolds warp and break the mounting bolts within the 1st 2 years of the trucks life.
04 D-Max Crew Dually
96 Monaco Dynasty 36'
MARKW8
Akron OH
Posted: 08/03/11 08:38am Link  |  Print  |  Notify Moderator
I don't know about the 8.1s but the 6.0s would pop the heads off the manifold bolts.
Mark
ole trucker
Florida.
Posted: 08/03/11 08:40am Link  |  Print  |  Notify Moderator
Will's '00 Endeavor
38wdd,01 2500HD
LIVALIL
Oh,I used to be disgusted, but now I try to be amused-
Elvis Costello
MrDoneIt65
Golf Country NC
Posted: 08/03/11 04:09pm Link  |  Print  |  Notify Moderator
It isn't the donut on the down exhaust pipe. I can put my hand in front of the exhaust manifold on the right side of the engine and feel the exhaust. There is a hole in the manifold but I am not sure it is a bolt hole. It appears to be an easy area to access but I will have to take off the front tire. Fleetwood also put some thin corrugated steel in the area between the frame and the coach support. I will cut that out with a Dremel and then replace it when I get the manifold off. You would be amazed at what I have had to do to keep this thing on the road for 30k miles. The mufflers fell off the first day I pulled it out of the dealer. And then I could never talk to anyone but the operator at the dealership after that.
I love camping!!!
