RV.Net Open Roads Forum: Towing Ford Sport Trac with a Ford V-10, Class A
Search only in Dinghy Towing
 > Towing Ford Sport Trac with a Ford V-10, Class A
denk
Michigan
Posted: 08/04/11 06:03am Link  |  Print  |  Notify Moderator
I'm thinking of looking for a Ford Sport Trac to use as a toad, for those towing one, what type of Ford Chassis/Engine to you have? And how do you like the chassis/engine doing the towing?
Denk
Michigan
sch911
Rochester Hills, MI
Posted: 08/04/11 10:37am Link  |  Print  |  Notify Moderator
Be advised that there are not too many gasser MH's that can tow a vehicle over 5K. Most have 5K hitches only....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
Kilgorehorn
KILGORE,TX,US
Posted: 08/04/11 05:02pm Link  |  Print  |  Notify Moderator
I towed a Sportrac with a driveshaft disconnect behind a 34' Hurricane with the V10 for 4 years with no problems. I hardly knew it was back there.
2000 Gulfstream Scenicruiser 39'
2011 Ford Flex
1946 DH
1952 DW
2008 Yorkie
427435
Rochester, Mn
Posted: 08/04/11 04:00pm Link  |  Print  |  Notify Moderator
How old a Sport Trac and what drivetain------some can't be towed.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 74,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
Loren Ross
Reno, NV
Posted: 08/05/11 10:34pm Link  |  Print  |  Notify Moderator
I'm towing an 08 Sport Trac behind our 32' gasser. You can only tow Sport Trac's that are 4WD, not AWD... Mine is the V-8 (which actually gets better MPG than the V-6) and my tow weight is approx. 4750 pounds on a 5000 pound hitch. I did upgrade everything else, however to at least 10K strength just to be on the safe side. The hitch has handled it just fine, no damage or stress showing after towing 9K miles. My Towbar is a 10K rated bar too, so nothing to worry about there.
When you find the one you want, I can help you with the Ford Neutral Tow Kit if your dealer can't get one. (You can make your own for less than $12). Send me a PM with your Email address.
RicJones
So. Cal.
Posted: 09/18/11 11:10am Link  |  Print  |  Notify Moderator
Thread
You will probably need the neutral tow kit mentioned in this link.
