RV.Net Open Roads Forum: hot water heater not working on electricity
Open Roads Forum  >  Hybrid Travel Trailers
 > hot water heater not working on electricity
bubbahemi
London Ontario
Posted: 08/05/11 08:29am Link  |  Print  |  Notify Moderator
have a suburban SW16DE gas/electric combo water heater.
last trip, was running it on electricity and it stopped working.
the fuse was tripped, I reset it and it still didn't come back on. checked the switch on the unit and its set to "on". tried the reset buttons (2 black buttons) and that didn't fix it.
gave up and switched over to propane and all was good. I would like to get it working on electricity again, but don't know what to do next.
suggestions?
Oh, BTW this is in a '08 Roo 233
thx
Chuck_S
Broadview Hts, OH, USA
Posted: 08/05/11 08:44am Link  |  Print  |  Notify Moderator
It's possible the heating element is burned out and shorted itself. Takes some disassemply of the gas piping to get at the electic element but it's a high use item and should be at any RV place or hardware store.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
Rookiecamper
Northeastern, PA
Posted: 08/05/11 09:55am Link  |  Print  |  Notify Moderator
bubbahemi wrote:
the fuse is not being tripped anymore.. only the one time. if it was shorted out wouldn't it trip everytime its reset?
It may have just tripped it as it blew out. Now that it is shot, there is no conductivity, so it won't trip the breaker. I've had that happen with light bulbs in the house....flip the switch, flash from the bulb, then everything out. As the bulb blew, the breaker tripped.
Me~Jim,52
DW~Patty, no comment
DD~Emily,19
2005 Expedition Eddie Bauer
2014 Starcraft Launch 21FBS
bikendan
Camano Island, Wash.
Posted: 08/05/11 12:18pm Link  |  Print  |  Notify Moderator
could you have turned the electric element on without any water in the WH? that would have burned it out.
Dan- Firefighter">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 Ecoboost, 2016 PrimeTime TracerAIR 255 w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
bubbahemi
London Ontario
Posted: 08/05/11 12:32pm Link  |  Print  |  Notify Moderator
nope... it was full of water. was at a site for 6 nights and on night 3 the tank was cold. nothing i could do to get it to start again. switched to propane and all was good.
can I test the connections to see if there is electricity somehow?
bubbahemi
London Ontario
Posted: 08/05/11 09:13am Link  |  Print  |  Notify Moderator
thanks for the quick response and pictures.
is the electrical connection on the heating element something that is a black and white wire? in other words, can I put a volt meter on the two connections to see if I am getting power?
Starcraft197rb
Saint Louis, MO
Posted: 08/05/11 07:39pm Link  |  Print  |  Notify Moderator
You can do it with an ohm meter connected to each terminal of the element. There should be an expected ohm reading somewhere on the water heater.
Make sure the breaker is off before testing the element.
2012 Coachmen 272BH
2007 Jeep Grand Cherokee 4.7 V-8
2006 Bayliner 197
Chuck_S
Posted: 08/06/11 05:56am Link  |  Print  |  Notify Moderator
You can check for voltage at the element. These plug into the trailer's system at a standard wall socket that may be assessable.
You really have the 16 gallon model, SW16DE? I'd have thought you had the standard 6 gallon version, SW6DE
-- Chuck
