RV.Net Open Roads Forum: Resurrecting a Class B
 > Resurrecting a Class B
LonerGlide
Ok
Posted: 05/03/12 01:42am Link  |  Print  |  Notify Moderator
Hey oldradios,,, hows the van comming along?,, how did ur first camping trip go?,, im close to having mine ready along with my 12x6 cargo trailer,,, heading for Colorado if i leave this summer and the gulf coast if closer to winter,, taking the old Harley and all camping equip and also the metal detectors ,,heck,,maybe even go adopt a pup for travel buddy but times gettin close,,,,ive been looking for other B's like ours and u just dont see many on the rd now days gonna have an adventure of it!!
OldRadios
Upstate New York
Posted: 05/03/12 05:26am Link  |  Print  |  Notify Moderator
I've got my first radio show of the year coming up end of next week in PA (three days). I'm replacing all the old blinds and my wife made new curtains for it. It's going in for an oil change and check over on Monday. It started right up on the first turn of the key this Spring (after charging the batteries). Still gets too cold here to flush out the RV antifreeze and add water but I don't need the toilet or water next week as they have bathrooms and showers there.
I want to replace the steering box and get new tires on it this year. I figure about $1,200 for both. I have been thinking about a new paint job but money is tight so the paint job will probably have to wait. Besides, people get out of my way when they see it coming.
NewsW
US
Posted: 05/03/12 05:39am Link  |  Print  |  Notify Moderator
Very nice, can imagine after a redo of decor and some paint how sharp it will become.
Can you tell me what makes you think the steering box is bad?
What is the mileage on it?
Normally, the steering box is not a big issue on that model, but the ball joints and other steering components are --- even at very low mileage I have seen ball joints go.
That might save you quite a bit of money.
Are the tires over 7 years old? If so, consider replacing them even if they have plenty of tread.
OldRadios
Upstate New York
Posted: 05/03/12 05:58am Link  |  Print  |  Notify Moderator
The B is on a Ford Econoline E250 chassis with 84,000 miles on it. Not bad for a 1985. The tires have lots of tread but I don't know how old they are. I'd rather have tires I know the history and age of.
The steering box leaks so it needs to be rebuilt or replaced. Front end has been inspected and is tight so no problems there.
LonerGlide
Ok
Posted: 05/03/12 09:35am Link  |  Print  |  Notify Moderator
Mine is on a chevy chassis and has 81.000miles and i had to totally rebuild the frontend,,,everything!!,, was shot and went back with better than stock parts but steering box was fine!!
Ive still got acouple tires to buy and going to put rear brakes,shocks and check bearings and axle seals but close to done other than an inverter an house batteries!
Handbasket
Asheville, NC
Posted: 05/03/12 10:39am Link  |  Print  |  Notify Moderator
Old radios, a very neat unit! Hard to tell from the pix, but a good cleaner-wax & some elbow grease may be all the roof needs to bring it back to life. I like plain old Turtle Wax, tho' depending on how bad yours is, you may need a more aggressive & abrasive product like rubbing or buffing compound. 3M used to make a fiberglass cleaner, but I never got good results from using it. And a second on John's advice to check with a boat shop.
Tires... yours may or may not need replacing based on age. There's a week & year date code molded into the sidewall. I think most tire maker's sites have info on finding and reading it. Do check that they're the correct load range, probably LR 'E'.
Jim, "Copper wire was invented in Scotland... two Scots arguing over ownership of a penny."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
OldRadios
Upstate New York
Posted: 05/03/12 10:57am Link  |  Print  |  Notify Moderator
The tires are LT235/85R16
It looks like the date code is 1802. If that's April 2002 then it's definitely time to replace them.
Handbasket
Asheville, NC
Posted: 05/03/12 11:17am Link  |  Print  |  Notify Moderator
Probably a door post sticker on driver's side stating what size & load range that the van was designed for. Yep, sounds like it's replacement time.
I specify 'not more than 6 months old' when I buy RV tires, and the tire dealers have met that requirement each time. Last time, I got two that were only a month old.
Jim, "Smile: To expose part of one's skeleton in a gesture of good will toward one's fellow beings."
OldRadios
Upstate New York
Posted: 05/03/12 12:50pm Link  |  Print  |  Notify Moderator
I think I'm going to replace them before my trip next week.
Been calling around and found a wide range of prices.
Best for the money around here seems to be the Sigma Stampede model by Cooper. I've found bad reviews on almost everything I was quoted but since these only get about 1,200 miles a year on them I don't think it will make much difference which ones I put on there as long as they are not too noisy and they meet the load rating.
NewsW
US
Posted: 05/03/12 02:20pm Link  |  Print  |  Notify Moderator
As people on here know, I am the weight / safety / hazard police....
Any tire used in RV (heavy load) is too old if it is past 7 years from date of manufacture.
The rigs we run are so unwieldy (tall, not necessarily balanced) that rolling it is not hard.
A blowout can come without warning.
The old tires can be given away --- to someone else riding an empty van in the city where the risks are a lot lower.
If the spare is old as well, pick the freshest one / best shape to be your future spare unless you want to buy 5.
When you buy new tires, be sure you check the date code to get fresh tires.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
I got good deals from Walmart / Sams Club / Costco, etc.
Decent service / support replacement policy.
A check of their manufacturer code tells you who made it.
Do stay away from tires not made in reputable places.
US, Japan, S. Korea, Germany are OK...
