Bakersfield
Bakersfield
Nice job.
Macs Dad
SoCal
Nice filter. I was going to just add a cheap high flow in line clear plastic type between the tank and pump and another one at the fuel line that feeds the gen from the tank as it looks like they are seperate feeds. The Onan 4000 manual shows the gen having a fuel filter on the left side of the gen. Good luck getting to it to change it while it'd in the trailer.
07 Weekend Warrior SL2805
05 Chevy 2500 HD Crew Cab 6.0/410 Gasser
08 Polaris RZR
06 KX 250F
adams92207
Ventura County, California
my996duc1 wrote: danojeno wrote: Mine has a high pitched buzz for the first few minutes of charge, then it disappears...does your noise disappear after a while?
Mine seems to be buzzing all the time now (when nothing 12v is on).
Yesterday it quit for abit but today it is non-stop.
I talked to the guys at Attitude/Eclipse to see if they had heard of this problem. They thought it might be a relay. I will try to take mine over to them next week and see if they can find the problem.
_
Good info so far guys! I am in email correspondence with them and mine is in pre delivery inspection as of today at the factory. it is getting inspected tomorrow so im hoping to possibly get it this weekend. I will be looking at all these things and asking lots of questions.
2003 Ford F250 CC 7.3 (the last of the best)
2005 Honda 450X
2005 Honda 400ex
2003 Harley Road King
2012 Eclipse Stellar 28SBG w/slide
(Dont buy from richardsons rv in riverside california)
adams92207
Macs Dad wrote: Nice filter. I was going to just add a cheap high flow in line clear plastic type between the tank and pump and another one at the fuel line that feeds the gen from the tank as it looks like they are seperate feeds. The Onan 4000 manual shows the gen having a fuel filter on the left side of the gen. Good luck getting to it to change it while it'd in the trailer.
Info from cummins site also says it has filter.
http://www.cumminsonan.com/rv/products/gasoline/compare?gensetId=130&detail=true
Aquaholic502
Paso Robles, Ca.
Has anyone put LED's in the existing fixtures yet? I would like to put some of the Rigid industries LED's but they are on a flat plate and the inside of the fixture is rounded so not sure how well they would mount.
my996duc1
SoCal
Aquaholic502 wrote: Has anyone put LED's in the existing fixtures yet? I would like to put some of the Rigid industries LED's but they are on a flat plate and the inside of the fixture is rounded so not sure how well they would mount.
I want to try to replace the actual bulb with a LED assembly rather than replacing the bulb with a wired flat panel of LED's.
I do not even know what type of bulb (style) is in the overhead main lights but they are on the list to upgrade to LED.
Here are a couple places I have seen the LED lights (not sure if they have what is needed yet) :
http://www.campingworld.com/shopping/pro........l-bulb-with-wedge-mount-connection-/9284
or here, maybe :
http://www.superbrightleds.com/cgi-bin/s........gi?action=DispPage&Page2Disp=%2F1157.htm
*** EDIT *** went out and looked. The fixture says to replace with a "921" bulb. I would guess that is the base style needed.
_
edited 11/30/11 08:36pm by my996duc1 *
2007 Coachmen Cross Country 354MBS
2005 LJ Rubicon Sahara
Aquaholic502
Paso Robles, Ca.
I believe the type of bulb is called the wedge mount in the fixture. You can get them with the the bulb only or the plate like rigid industries. I like the rigid ones because they are 450 lumens for the bright ones and 315 for the other and a lot of other companies that make them are less then 300 lumens.
Bakersfield
Bakersfield
Quote: =Racorman I just finished building out the battery cabinet to accomodate (4) six volt batteries and also installed a 2000 watt inverter.
Question: did you have to add any support in the tray, or did the four six volt batteries fit in the orginal space?
Thanks
Aquaholic502
Paso Robles, Ca.
Well I took a better look at the light fuxture today and they are not rounded on the inside but have like a heat sheild. So I think im going to order some of the rigid lights because I bought some LEDs from a local store that was $30 and only 250 lumens. For the price and brightness of the rigid lights I think its best to get them.
Racorman
Santa Cruz, California
Bakersfield wrote: Quote: =Racorman I just finished building out the battery cabinet to accomodate (4) six volt batteries and also installed a 2000 watt inverter.
Thanks
Yup...... I needed to do some modification and add additional support to hold the (4) 6 volt Interstates
AKA..... 56Nomad
Attitude FL28AKLG 5th wheel
2011 Can Am Commander
Chevy 1 Ton Duramax/Allison 4x4 -Edge w/Juice and 4" Exhaust
