RV.Net Open Roads Forum: Technology Corner: Digital TV signals and HDTV
 > Digital TV signals and HDTV
NY
Posted: 08/08/11 05:40pm Link  |  Print  |  Notify Moderator
Are any of the Digital TV signals being broadcast now, being broadcast in HDTV? Just curious if my HDTV in the RV is getting an HDTV signal through the batwing antenna on the roof is the same as the HDTV that is coming into my house from the cable company (which needs a special HDTV tuner box). The connection to the TV in the RV is coax and not an HDTV connector cable (as I assume most if not all rv tvs are connected by coax).
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
therink
Rochester
Posted: 08/08/11 05:50pm Link  |  Print  |  Notify Moderator
You should have no problem receiving hd digital signal with yge batwing assuming you have a digital hd tv and it is configured properly. No need for special box for over the air signals. I did find though that I have to rotate the antenna quite a bit to get good signals though.
Steve
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
texasrat
Las Crusas, NM USA
Posted: 08/10/11 07:39pm Link  |  Print  |  Notify Moderator
camperpaul wrote:
No special tuner needed - Everything is built in to the TV set.
Almost true
I have an older 720P flat screen and it does not have a digital tuner so it won't get HDTV unless I use a converter box.
Yes it is very old and newer ones do have the tuner
TexasRat
camperpaul
Wherever I park my travel trailer
Posted: 08/08/11 06:11pm Link  |  Print  |  Notify Moderator
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
jbarry
California
Posted: 08/08/11 06:51pm Link  |  Print  |  Notify Moderator
I was pleasantly surprised to find that my newly installed HDTV got excellent HD pictures with just the batwing antenna. I have found that you have to be much more precise in aiming the batwing for digital reception. My next upgrade will be the "wingman" attachment to the batwing.
tatest
Oklahoma Green Country
Posted: 08/08/11 07:55pm Link  |  Print  |  Notify Moderator
Over the air HDTV that comes into your HD TV through the antenna connection is not the same as the HDTV on your digital cable box. It is much better, as it is a higher bandwidth signal, allowing more of the video stream to come through unaltered from the way the network sent it out.
The cable and satellite companies need to further compress the HD stream to fit it into the available bandwidth. Sometimes the additional compression gets really annoying, as when a person turns his head slightly in a closeup shot, and his nose moves but his cheeks don't, or they move at slightly different times.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
PyrateSilly
Home
Posted: 08/10/11 08:02pm Link  |  Print  |  Notify Moderator
At the house we have a converter on an old TV and we get just over 20 channels. Most of them are HDTV. Did not want to pay for any dish stuff since they do not do the internet there. Cable stops a mile or so and they have no plans to go any closer. Since we would rather have the internet than 100's of channels that we would not watch anyway we decided against anything but the converter box.
Thom, Gascap and Christine having fun in a 1993 Monaco Crown Royale 40ft 300hp RV.
Our blogged repairs and travels
MrWizard
Traveling
Posted: 08/10/11 08:12pm Link  |  Print  |  Notify Moderator
All major network prime time TV & sports, new movies are in HD
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
1775
NY
Posted: 08/10/11 09:40pm Link  |  Print  |  Notify Moderator
Thanks for the responses! The RV has an LED/LCD screen, digital tuner HDTV so now I know that the signals coming through are actually HDTV.
Wherever I happen to park
Posted: 08/11/11 10:46am Link  |  Print  |  Notify Moderator
Yes. Many stations have both SD and HD broadcasts.. For example where I"ll park next week I hope to bet Chan 2 out of Detroit
2-1 is SD
2-2 is the same show in HD format.
No special anything needed, if your TV can get 2-1, it can get 2-2 but you may need to change a menu setting to properly display it. (Picture format from "normal" to "Letter box" or some such If you have an older tv this is done in the converter box.. It may be done automatically) If you have a newer HDTV then you change from "Pillar box" for SD to "normal" for HD) (And again, Automatic may be the way it's done)
