gman03842
Newmarket, NH
This will be our 1st trip with the new 5th wheel. Water pump runs but no water comes out. This is the 1st time with the water panel that comes with a 5th wheel, TT seems to be a lot easier to begin with. Have the switches in 1 and 6 for city tank fill. Also tried 2 and 6 for city water. Still no water, tank os 1/3 full. Any help would be appreciated.
Thanks,
Greg
Gregory LaCourse
2012 GMC Sierra Denali 3500HD CC Duramax 4x4
2011 Jayco Eagle 321RLTS
donn0128
Pronounced Ore-gun
Did you actually put water in the tank? If the answer is yes, then go out, find the water pump and be sure that the valves are in the correct positions. remember that the water heater tank needs to be filled before you see anything out of the faucets.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
RedG
Fort Worth Texas
donn0128 wrote: Did you actually put water in the tank? If the answer is yes, then go out, find the water pump and be sure that the valves are in the correct positions. remember that the water heater tank needs to be filled before you see anything out of the faucets.
X2. It takes a while to fill the water heater with the pump. You should be on normal, not city water or city fill.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
fordsooperdooty
gman...great opportunity to call Jayco's Customer service (1-800-RVJAYCO) and ask them to talk you thru it. My guess is that the winterization valves are set wrong. You might want to double check they're positions with the Jayco owners manual.
And Congratulations on your new Jayco and welcome to the Jayco Family!
northmeck0255
Piedmont area of North Carolina
One thing to remember with the water panel is that "Normal" in Jayco-ese means "I have water in the tank and want to run it with the onboard pump".
If you have it set to City Fill, you are bypassing the pump. The panel was confusing to me as well. You get the hang of it after a while.
1989 Bluebird SP36
"$TIMULU$ PACKAGE"
hmknightnc
Wilmington, NC
On my 5th Wheel if the city fill valve is open you are essentiall bypassing the water pump (connects pump discharge to pump suction, pump suction line is also the city tank fill line). Make sure the pump suction valve is open and the city fill valve is closed.
gman03842
Newmarket, NH
Thanks for all your quick replies. Went out and looked at it again, and found the normal setting. I decided to get the Jayco Manual and do some reading. It was on city fill, and not normal. Also found out by reading how to sanitize the system. Starting to get the hang of it.
Thanks Again,
Greg
twins89
Western New York
It takes awhile but you will get it and when you don't there are lots of smarty follks here to help you.
Parents who still don't know anything
Twin college graduates who know everything
One lazy Westie
2000 F350 DRW 7.3 PSD crew cab
2007 Jayco Eagle 291 RLTS
2003 Coleman Sedona towed by 99 4Runner for the "graduates"
