wormy
NC
I have found WD-40 to the absolute best cleaner for the exterior on my fiberglass TT. It is amazeing for cleaning stained slide seals and removing black streaks and mold from molding. I really havent found anything that it wont remove. I recently replaced some decals and had a hard time removing the dried adhesive. WD-40 took it right off very easily.
My question is it really good for the rubber seals etc. Could it maybe dry them out. I did notice the seals are a little "sticky" when I run out the slides.
RoyB
King George, VA
USES FOR WD-40
Here you go....
I also use it to spray into my trailer connector plug to cleanup the trailer contacts before I hook up.
Every RV guy I know has a WD40 spraycan in his truck door side pocket.
EDIT NOTE:
it says - Lubricates rubber insulation around storm doors
edited 08/10/11 08:47pm by RoyB *
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Trailer Trash 2
Santa Fe Springs, CA
I love the stuff, it also absorbs water so if the water heater gets wet spray them wires and it will work real good.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
2009, Dodge, 3500, Q Cab, Cum/Diesel, D.R.W.
Pulling a Super Fine Montana 2980RL
hmknightnc
Wilmington, NC
Awesome stuff!!! Keep a can in every vehicle (3), every trailer (3) and boat. Small can in every tool box. Ought to be stock in the stuff
1775
NY
The company states on their website that it is safe for rubber so, hopefully, it must be. They will not say what it contains but it sure smells like it is petroleum based (which would not be good for rubber). I suppose if there was a problem one could always take action against the company saying it is safe for rubber.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
micah43
Central Fl.
I didn't read the whole list but. spray some in the air cleaner of had to start mower or any motor, it will usually start on first pull. Masons use it to keep stucco from sticking to metal frames on buildings. Spray some on the base of a paint brush before using it, it will wash clean even if dried on. It is good to clean paint off hands also. I've heard that you can use it as a flame thrower, but i'm not going to try. Handy stuff for sure. Jerry
Keep the shiny side up.
E&J push'n wind
San Diego CA, The best climate on earth!
That's not all, it is an excellent cutting fluid for aluminum too! Used it in the machine shop for many years for that amongst many other things it can be used for. Excellent stuff!
Wisdom is the right use of knowledge. To know is not to be wise. Many men know much, and are all the greater fools for it. There is no fool so great a fool as a knowing fool. But to know how to use knowledge is to have wisdom.
Charles Haddon Spurgeon
ol Bombero-JC
WD-40 *is* petroleum based.
Of course, if the COMPANY says it's OK for rubber - it certainly must be!.
There are many far better choices for everything the OP mentioned, from cleaners, polishers, electrical connections, etc.
More of a solvent than a "lubricant" - ask a locksmith what he thinks of it.
Quick -"down and dirty"- for stuff you don't care about!
But - whatever rings your chimes - or (YIKES!) cleans your gelcoat.
Jim Shoe
Amelia, OH
WD-40, Duct Tape and a credit card - That's my entire tool box!
Retired and visiting as much of this beautiful country as I can.
SH
Lynden, WA
I don't think I would use it as a cleaner on my rig except maybe the undercarriage!
2011 Heartland Big Country 3450TS
2007.5 Chev LMM Duramax/Allison
2010 FLHTC Electra Glide Classic Red Hot Sunglo
Heartland Owners Club - Washington Chapter Leaders
