RV.Net Open Roads Forum: Tech Issues: High fridge temps
 > High fridge temps
45 ACP
Posted: 09/06/11 11:31pm Link  |  Print  |  Notify Moderator
fuzzbutt wrote:
I do have a question about the placement of the thermister. I have seen it reported to move it up, and also down to make it colder in the fridge. Either one of the suggestions is wrong, or it doesn't make any difference anyway.
F.W.I.W. Mine is near the bottom of the fins.
It is my understanding that raising the thermistor (i.e. placing it at the TOP of the fins) will result in cooler fridge temps. Since it has nowhere else to go heat rises inside the fridge, so by raising the thermistor the result will be the fridge calling for cooling more often and longer, thereby resulting in lower temps inside the box.
I was having similar cooling problems during a real hot spell last weekend. I already added a second fan in the back of the cabinet, I have the internal "E-Bay" twin fan, and I had switched to propane only. My fridge (Dometic 2862) is in a slideout, so I honestly believe it's not as efficient as a roof-vented arrangement.
I discovered that the thermistor had slid it's way down inside the plastic fin "mount" while traveling. Sliding it back up to the top and staying on propane solved my problems.
2012 Ford F-350 6.7L 4x4 Lariat CC DRW
2011 Blue Ridge 3025RL
rvmut
granada
Posted: 09/07/11 08:13am Link  |  Print  |  Notify Moderator
fuzzbutt
Pittsburgh
Posted: 09/07/11 12:20pm Link  |  Print  |  Notify Moderator
I am going to raise the thermister up on the fins just for the heck of it. it is near the bottom now. I am curious to see if it makes a difference. Hopefully I will get out again before winter to test it.
John, Sherry & Sabrina
+ Mowgli (Keeshond) Shane (Border Collie) Sunny (Sun Conure) & Lily (Cockatiel)
94 Winnebago Adventurer 34'
04 Nissan Murano
05 Acura TL
92 Honda Gold Wing
Now.....bring me that horizon.
JC2
Mo
Posted: 09/07/11 02:52pm Link  |  Print  |  Notify Moderator
It should be about 1/3 of the way down from the top, not on the bottom.
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
vermilye
Oswego, NY, USA
Posted: 09/08/11 09:30am Link  |  Print  |  Notify Moderator
In addition to adding fans, etc it is worth checking Dometic's "Venting PDF" It gives clearance information that is useful, particularly the maximum clearances. It can be downloaded from http://bryantrv.com/docs2/docs/dometicventing.pdf.
Jon Vermilye Travel & Photo Web Pages ... My Collection of RV Blogs & Journals
My Travel Journal - Jon's Journeys
Lake McDonald, Glacier National Park, MT
 > High fridge temps
