larry barnhart
wenatchee. wa usa
I have sprayed the rod from the outside and this helps but the best method that works great is dunp a gallon of vegtable oil in the empty tank and let it sit. the go outside and quickly pull and push the rod so it get lubed as the oil passes by. We really don't have a problem because of the two methods we use.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
asphalt sailor
granite state
Eat more olive oil.....
workhardplayharder
Treasure Coast Florida
Tom_Anderson wrote: Eat more fried foods.
Great minds think alike.
-Gramps-
Portsmouth VA
Vaseline.
___________________________________________
08 Holiday Rambler Vacationer 38PLT Workhorse UFO GAS Pusher Chassis
06 Saturn Vue toad, SMI Breaking sys,Blue Ox tow bar.
My FMCA Blog
down home
south
Deep Fried foods...perhaps deep fried butter
Brian in Michigan
S.E. Mi.
down home wrote: Deep Fried foods...perhaps deep fried butter
Put some sugar on it and you have a great shame stick
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS, Thorley Headers B&M trans cooler. Auto meter hooked to output of trans. Flowmaster mufflers recurved distributor Still Keepin on Truckin((((Was 7.5mpg Now 8.75mpg ))))
Happy Jim
Owensboro KY
Good Grief
Travel Safe - Enjoy
Happy Jim
1999 Holiday Rambler Vacationer
2006 Chevy HHR Toad
fuzzbutt
Pittsburgh
Since everyone is in a jolly mood, I will share my story from last night. The names have been changed to protect the innocent.
The last time out, I had a hard time opening and closing the black dump valve. When dumping I flushed it "really good" knowing I would be taking it apart.
The plan last night was to take it apart, clean and lube it, and re-assemble it. I did have the presence of mind to put a bucket under the assembly. I tooks the 4 nuts off, removed the bolts and had to pry the assembly apart with a screwdriver. When I did that, I was expecting a little dirty water to trickle out into the bucket. I was not mentally prepared for the "slurry" that ran out into the bucket. I told my wife that as bad as i was expecting it to be.....it was 5 times that bad. My stomach still gets a little tight when I think about it. In hindsite, I should have raised the drivers side of the motorhome so all the nasties were running AWAY from the outlet. Lesson learned. Hopefully I will never have to do that again!!!!!
However, my PM did work and the valve functions like new aqain.
John, Sherry & Sabrina
+ Mowgli (Keeshond) Shane (Border Collie) Sunny (Sun Conure) & Lily (Cockatiel)
94 Winnebago Adventurer 34'
04 Nissan Murano
05 Acura TL
92 Honda Gold Wing
Now.....bring me that horizon.
wolfe10
John,
Sorry it was such a dirty lesson. When preparing to work on the valves, raise the opposite side of the coach and dump, then raise the side with the valves before beginning work. You should not get a cup out of it then.
BTW, I have found that a quality silicone grease applied on the uninstalled valves keeps them easy to operate for a whole season.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
fuzzbutt
Pittsburgh
wolfe10 wrote: John,
I will certainly do it a little smarter the next time. The only bad mistake is the one you don't learn from. I didn't realize that held that much stuff when it was level.
Thanks!
Thanks!
