RV.Net Open Roads Forum: Travel Trailers: Convert gas furnace to electric
 > Convert gas furnace to electric
M00d
Mississippi
Posted: 08/13/11 01:28pm Link  |  Print  |  Notify Moderator
Has anyone converted their gas furnace to electric? Would it be possible to keep the existing blower/thermostat and replace the hearth with one or two heat strips? It sure would be nice to have ducked electric heat.
Larryect
Home
Posted: 08/13/11 01:37pm Link  |  Print  |  Notify Moderator
Most of the AC units have an option to add electric heat. That is probably a much simpler way of adding electric heat to a rig.
M00d
Mississippi
Posted: 08/13/11 01:41pm Link  |  Print  |  Notify Moderator
I don't think you can add a heat strip to ducked AC systems like mine. At least I haven't seen it, correct me if I'm wrong.
weathershak
Not sure, I need to look out the window
Posted: 08/13/11 01:42pm Link  |  Print  |  Notify Moderator
It probably could be done on a small RV. Some rigs have heat strips in the AC, which are ok to take a chill out. I winter camp. I use 2 1500 watt electric heaters, when power is available, and still need the gas furnace to kick on on occasion. 3 heaters might cover it, but not with 30 amp service. I am not sure how many amps would be needed to make an electric furnace capable of matching the btu's of my propane furnace.
Full timing it since July 2012
skipnchar
Topeka or somewhere else
Posted: 08/13/11 01:45pm Link  |  Print  |  Notify Moderator
Your RV furnace is probably between 20,000 and 60,000 BTU depending on it's size. that would take an AWFULLY lot of electricity to come even CLOSE to replicating that amount of heat.
garym114
Bluff Dale, Texas
Posted: 08/13/11 01:46pm Link  |  Print  |  Notify Moderator
To heat an RV on very cold nights would probably require more power than even a 50 amp connection could deliver.
M00d
Mississippi
Posted: 08/13/11 02:04pm Link  |  Print  |  Notify Moderator
Here in MS it usually doesn't get much colder than 20 at night. We sometimes have a cold snap during the winter where we might see single digit temps for a night or two, but that is very rare. Last year in my driveway I ran a 1500 watt heater and the floor furnace full blast one night when the temps went into the teens an my RV only reached the upper 60's. I must have a low btu floor furnace, need to check that. I believe two electric heaters would put out more heat than my gas furnace.
I have a 33' bunkhouse, basically a three room rv. I'm thinking of installing three of the below ceiling mount heaters, one in each room. I think that will keep us toasty down to 15 or so degrees, at that point I'd have to kick on the furnace for some added heat.
pianotuna
Regina, SK, Canada
Posted: 08/13/11 03:16pm Link  |  Print  |  Notify Moderator
Hi,
I am able to heat my RV on 4500 watts of electric heaters. That would be at temperatures of -25 C and lower. That represents about 15000 BTU's. My hourly loss is about 9000 btu's.
On a 50 amp RV 12000 watts would be available for heating. That is nearly 41000 btu's--or enough to heat a pretty darn large RV.
There is an "add on" kit that can be retro fitted to an RV allowing the propane furnace to remain intact. It is not inexpensive. Here is a link to it:
Cheap Heat (NOT)
Instead of getting that unit, I'd recommend upgrading the air-conditioner to a Heat Pump.
I have added a 2nd thermostat for my furnace only so I can use the heat strip in my ducted air conditioner. I set the furnace to "cut in" at a lower temperature.
I've also added a thermostatically controlled fan to under the kitchen cabinets to prevent water lines from freezing when I'm running on electric heat only. A nice side benefit is that it causes some air to flow through the regular furnace ducts.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
M00d
Mississippi
Posted: 08/13/11 03:30pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
Cheap Heat (NOT)
Don,
How large is your rv and how well would the heat pump do by itself?
If the temp were zero Celsius what would be the inside temp of your RV using only the heat pump? I love the idea of the heat pump as it would use my existing duck work/wiring and be a simple solution, although a bit more expensive that electric heaters.
Thanks
ScottG
Bothell Wa.
Posted: 08/13/11 03:54pm Link  |  Print  |  Notify Moderator
I looked at the "Cheap Heat" system and it's $1000!!!
How the heck is that cheap??
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
