RV.Net Open Roads Forum: Norcold ice maker has a mind of it's own
 > Norcold ice maker has a mind of it's own
bob b
Grants Pass, Or
Posted: 08/14/11 08:31am Link  |  Print  |  Notify Moderator
Most times we hook up and soon hear the sound of water flowing in to the ice maker and a little later the crash as ice drops down into the tray. On occasion, like last week, no ice. It's like there is a hidden switch that has been turned off! Of course I dropped the bale in the tray but that had no effect! Any ideas where to start? Thanks in advance, Bob
bob b
past-MIdirector
Michigan
Posted: 08/14/11 08:38am Link  |  Print  |  Notify Moderator
Ice makers are controlled by a thermostat and if the freezer does not get cold enough to open the thermostat then no ice will be released. The thermostat is inside the ice maker and usually set to open around 5-0 degrees.
docj
Fulltime--Home is where we park it
Posted: 08/14/11 09:08am Link  |  Print  |  Notify Moderator
Our Norcold icemaker is prone to having pieces of ice stick in the mechanism instead of being cleanly released. Check on top of and behind the mechanism to see if there is a small piece stuck there.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
chewbear
Mobile in the USofA;currently Ozark, Alabama
Posted: 08/14/11 09:33am Link  |  Print  |  Notify Moderator
If you believe your freezer is cold enought, try filling the tray with water using a small cup. Most times this will get it to start cycling.
2002 Fleetwood Discovery
330 cat. '09 Escape toad.
Kathy & Joe wish you well.
My mind works like lightning,
one brilliant flash and it's
gone. (Maxine)
ticat900
canada
Posted: 08/14/11 09:56am Link  |  Print  |  Notify Moderator
Correct me if iam wrong but ice makers go through a cycle and if u shut your fridge off 1/2 way through the cycle does it not have to finsh the cycle when u restart your fridge the next time?Before it refills and starts over.
also Your not going to get any ice in the first 4-5 hours because it will take that long for the fridge to get cold enough.
btd35
Spokane, WA
Posted: 08/14/11 10:59am Link  |  Print  |  Notify Moderator
Ice makers! Cheap little things. I've been servicing appliances for over 20 years, and will say that I swear manufacturers make em cheap so they can sell replacements. Depending on the style you have, it may need to be jump started when you start it up. Others have a cheap little tab that activates the bail switch. It breaks off easy, and there isn't enough there to glue anything back on to activate the switch. However in your case, I think you will just have to jump start it.
Here is a link with the directions.
http://www.appliance-repair-it.com/jumping-icemakers.html
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
RCtime
So. Calif.
Posted: 08/14/11 11:30am Link  |  Print  |  Notify Moderator
Ron
2002 34HD Winnebago Journey DL, Cat. 330/freightliner
2004 Honda CRV - Garmin 1490t
Great wife & Cavalier King Charles Spaniel
TT/N
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 08/14/11 12:50pm Link  |  Print  |  Notify Moderator
Pull off the outside access door to the fridge. This where the small pump is typically located; make sure that it hasn't come unplugged. Another thing is make sure your water supply is turned on. If you are not connected to city water, you need to leave the water pump on.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
