RV.Net Open Roads Forum: Can I use car tires on my traile ?
 > Can I use car tires on my traile ?
truckerfleck
rochester
Posted: 08/17/11 11:48am Link  |  Print  |  Notify Moderator
Hi, I have a small 6X10 ft utillity trailer that needs new tires. I can get auto tires for the same price as trailer tires. The auto tires sound like a better deal but am I missing anything here why I shouldnt do this ? Thanks for any thoughts.
RandACampin
Kathleen, Georgia
Posted: 08/17/11 11:58am Link  |  Print  |  Notify Moderator
Single axle..no problem.
Ivylog
Blairsville, Ga. USA
Posted: 08/17/11 12:09pm Link  |  Print  |  Notify Moderator
Buy car takeoffs for $25 as you will never wear even them out. I own a bunch of trailers of all size and takeoffs is all I run.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
jkwilson
Indiana
Posted: 08/17/11 12:13pm Link  |  Print  |  Notify Moderator
Look at the load rating and make sure you are comparing apples to apples. The max load should be listed on the sidewall, and trailer tires TEND to be rated a little higher than car tires in similar sizes.
JIMNLIN
out here
Posted: 08/17/11 12:34pm Link  |  Print  |  Notify Moderator
I just sold a 10' tilt deck single axle trailer that I had for years. I kept P tires on the trailer as it was required to run I-44 near me at legal 75 mph speeds. Before ST tires were invented car tires (P) and truck tires were all we had. (LT)
Just so you'll know but a P tire mounted on a trailer is required by fed regs to have its capacity derated by 10 percent. A 1500 lb capacity P tire would be derated to 1350 lbs capacity.
'97 Park Avanue 28' 5er 11200 gvwr two slides
~DJ~
Boise, Idaho
Posted: 08/17/11 03:46pm Link  |  Print  |  Notify Moderator
Now there is a new one for me. Do you have a link for that, Jim?
2011 F250 Super Cab Lariat 6.2 373 FX4 Short Box 4" BDS, 35" Toyos, TorkLift, 16.5K Warn, Locked & Loaded
2007 SunLite Pop Up
johntank
Oxford, Ms 38655 USA
Posted: 08/17/11 03:48pm Link  |  Print  |  Notify Moderator
This is just my opinion, as long as the tires have a weight rateing for as much or more than the axle you should be ok.
JIM; can you give the fed reg that saids a P tire on a trailer has to be derated by 10%, thanks.
mowermech
Billings, MT
Posted: 08/17/11 04:44pm Link  |  Print  |  Notify Moderator
"Can I use car tires on my trailer ?"
Yes, you certainly may do so if you wish.
It is, after all, YOUR trailer.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
JIMNLIN
out here
Posted: 08/17/11 06:30pm Link  |  Print  |  Notify Moderator
S4.2.2.2 When passenger car tires are
installed on an MPV, truck, bus, or
trailer, each tire’s load rating is reduced
by dividing it by 1.10 before determining,
under S4.2.2.1, the sum of
the maximum load ratings of the tires
fitted to an axle.
This comes from 571.110 tire and rim selection for vehicles under 10k GVWR. Sectin 571.120 says the same for vehicles over 10k GVWR.
Ya' gotta remember when these regs were written we had many many different P or car tire sizes from a B78-13 up to a N/75-15 with many 50/60 and 70 series car tires with very tall sidewalls. Todays car tires with their wide wheel requirements and low sidewall height may not make a good tire for trailer use.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 08/17/11 09:32pm Link  |  Print  |  Notify Moderator
Depends on the load rating of the tires vs the load your carrying I expect. But if the tires are the same price, why not get the trailer tires to start with????
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
