RV.Net Open Roads Forum: Beginning RVing: Need help with digital t-stat upgrade
 > Need help with digital t-stat upgrade
racerzl1
Mississippi
Posted: 08/18/11 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Hello again. I am wanting to replace my analog thermostat with the digital one. I know to get a hunter t-stat(the kind with batteries) from Walmart, but I have questions on the wiring.
What I have is a dometic a/c unit, not sure of furnace brand.
It has the duotherm analog t-stat.
My wiring is what I have questions about.
Heres the way mine is wired.
+7.5= Red , cool=yellow , furnace=white , high fan=blue , fan=orange , ground=green.
I am headed camping this weekend and would really like to install a new thermostat,But, I don't want to mess anything up. I really would appreciate if one of you nice people would tell me how to wire this.
I saw another diagram showing power is 12v, but mine is apparently +7.5v.
My old analog thermostat ,I believe,is bad anyway, as the fan never shuts off,even when in auto mode .
Thanks in advance for any insight on this.
I am still wayne_tw
everywhere
Posted: 08/18/11 07:39am Link  |  Quote  |  Print  |  Notify Moderator
I made that upgrade and not very happy with it. I find the old analog works just as good as the digital and the old provided for two fan speeds for the A/C and the digitl does not. Keep what you got.
garym114
Bluff Dale, Texas
Posted: 08/18/11 07:40am Link  |  Quote  |  Print  |  Notify Moderator
The power and ground are not used. Tape over the red power.
The thermostat you use has to be battery powered, like two AA batteries.
Wire up one fan speed to use exclusively or put in a switch to select either speed.
stump_breaker
Great State of Texas
Posted: 08/18/11 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Super easy and as mentioned above, wire nut your power and ground.
Be sure your AC stays grounded just not through the thermostat. Took me 20 minutes of sweating to figure out why my AC wouldn't come on before I realized I had disconnected my ground completely.
Fire Instructor
Upstate (Albany) NY Area
Posted: 08/18/11 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Complete instructions here.
Or here.
Or here! (This is the set that I used when I made the same modification.
It's really an easy mod, so just read-up about it and go for it!
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
"If everyone is thinking alike, then someone isn't thinking!" General George S. Patton
racerzl1
Mississippi
Posted: 08/18/11 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
So, am I correct in thinking that I need to hook up the low fan to the orange, and take a jumper from there to the switch, and from switch to blue wire ,high fan?
So, If I don't have the switch right now, i can just hook the high and low fan wires together, attach to (orange)fan on t-stat and I will have just high fan,correct?
Or am I thinking wrong?
Thanks guys.
Or here.
RedG
Fort Worth Texas
Posted: 08/18/11 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
No, don't hook the high and low fan wires together. Just pick one (high if that's what you want). I bought a mini slide switch at Radio Shack and put it on my Tstat. Works great.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
racerzl1
Mississippi
Posted: 08/18/11 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Red, Where does the switch connect, if I choose to go that route ?
garym114
Bluff Dale, Texas
Posted: 08/18/11 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
The switch connects to the G on the hunter tstat.
The one marked relay to the thermostat, the ones each end to the hi and low fan wires coming out of the wall.
Ignore the labeling of the wires in the image.
RedG
Fort Worth Texas
Posted: 08/19/11 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Looking at the switch above, the fan wire from the tstat would go to the center terminal with the orange wire on one side and the blue wire on the other.
