RV.Net Open Roads Forum: Dinghy Towing: Flat Tow a new Fiat 500 ?
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > Flat Tow a new Fiat 500 ?
BWhite
Metrowest,Ma
Posted: 08/18/11 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Can this vehicle be flat towed ?
Bill and Patti
Gizmo a Black face Tri-color PWC
Laci a Red and White PWC
'06 Fleetwood Revolution LE 40E
'10 Hyundai Elantra Touring Coupe
Member Fans of Revolution Group, ,FMCA,CAT RV Engine Owners Club
gbopp
The Keystone State
Posted: 08/18/11 09:08am Link  |  Quote  |  Print  |  Notify Moderator
What did the dealer say?
fordsooperdooty
Posted: 08/18/11 10:21am Link  |  Quote  |  Print  |  Notify Moderator
We have found via a FIAT "Studio" (FIAT doesn't call them "Dealerships") that the manual transmission can be flat towed.
"RV owners will be happy to hear that the Fiat 500, with a manual transmission, can be towed flat behind a motor home; however the automatic version would need to use a tow dolly." iVeho.com
kaydeejay
SE Michigan, USA
Posted: 08/18/11 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Why tow it? Just pick it up and put it in one of your storage compartments
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
Big Katuna
Deland, FL
Posted: 08/18/11 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Another good source it REMCO.
My Kharma ran over my Dogma.
mowermech
Billings, MT
Posted: 08/18/11 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Usually, yes.
However, Fiat is not listed in the application charts.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Bumpyroad
Virginia
Posted: 08/18/11 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I would totally ignore what a dealer sez. look in the owner's manual under towing behind a motorhome or recreational towing.
bumpy
gbopp
The Keystone State
Posted: 08/18/11 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
bumpy
You're right, actually that is what I wanted to say but it was so much easier to just say dealer.
I know you should never take the advice of a dealer.
Thanks Bumpy
BWhite
Metrowest,Ma
Posted: 08/19/11 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
The Fiat 500 is to long ! It is 16.2 inches longer than the Austin/British Leyland etc Mini.
kaydeejay
SE Michigan, USA
Posted: 08/19/11 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, it doesn't look that big out on the road.
But then I guess the original Mini was kinda small (and I have owned 7 of 'em over the years at some point in my distant youth).
