RV.Net Open Roads Forum: Tow Vehicles: Performance programmers or chips
Search only in Tow Vehicles
 > Performance programmers or chips
Page of 6
Trail-Mate
Frederick, MD
Posted: 08/23/11 10:18am Link  |  Print  |  Notify Moderator
I run a TS 6 position Chip. I like the fast idle setting for cold warm ups and run the 50 HP setting all the time. Get 20 mpg with it empty and have 4:10 gearing.
If you want to add some power and not affect emissions. Snow Performance Methanol injection would do the job and lower egt.
Diesel World is currently doing an article comparing Methanol injection to Urea. From what I have seen so far Methanol injection reduces NOX and other emissions pretty good. Not sure when all the testing will be published.
1997 Ford F250 Extended Cab, 7.3 Diesel, 8 foot bed.
Reese 16K Hitch
(Moved into Shed) Hensley Arrow
Jordan Brake Controller, Hensley TruControl Gold Shelved.
Open Range 5th Wheel, Roamer RF392 BHS
Happy Camping !!
45Ricochet
North Idaho
Posted: 08/23/11 11:17am Link  |  Print  |  Notify Moderator
_Me2_ wrote:
Fisherguy wrote:
Obviously you haven't!
No, I've had a BC emissions test.
You cannot add 50 or 100 hp or whatever without affecting emissions, period.
CA doesn't measure emissions on diesels (yet). They do a visual, OBDII check, and visible smoke test.
Exactly.
Hey fisherguy, people do move. Born and raised in S Cali over 50 years so I have had a smog test or two. I was just wondering if the Smarty Jr would pass a typical test.
Just wonder how the tuner companies can get away with selling them if it is emission tampering.
This is a quote from the State of Maine Web site.
"Tampering with a vehicles emissions control system is prohibited by the Clean Air Act of 1990 (40 CFR Title 2, Part A, Section 203).Emissions controls on vehicles are part of the certified design from the manufacturer to reduce pollution and protect public health.
Tampering could include the removal, bypass, disconnection, damage or in any way rendering ineffective any emissions control device or element of design that has been installed on a vehicle or engine.
What are the implications of motor vehicle tampering?
Civil Penalties
A manufacturer or dealer who removes or renders inoperative any emission control device or element of design installed on or in a motor vehicle or motor vehicle engine is subject to a civil penalty of up to $25,000. Others can be fined up to $2, 500. Anyone manufacturing, selling or installation of any part or component that serves to bypass, defeat or render inoperative any emission control device or element of design is subject to a civil penalty of up $2,500."
Clearly a 25k fine so I assume it isn't tampering.
Just saying
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
jauguston
Bellingham, WA
Posted: 08/23/11 06:45pm Link  |  Print  |  Notify Moderator
Rick,
Assuming anything can be wrong. There are hundreds of thousands of vehicles on the road every day with altered emission systems. Some time do a web search and see how many documented cases of successful prosecution for altering emission systems you find. Me thinks you cry wolf a little too much.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Fisherguy
Vancouver BC
Posted: 08/23/11 07:08pm Link  |  Print  |  Notify Moderator
I don't think adding a programmer is "emissions tampering" since you're not actually removing any of the emissions components.
Either way I'm not worried about it, when time comes I need to go for a test I'll just put the settings back to stock. I haven't removed any emissions equipment, still have my cat on etc.
I've been running the Bully Dog for 4 years and it's never given me any grief, I love it. Running at stock settings is painfull. I've since added a Quadzilla X2 and use it only for adding rail pressure. I go easy on it and only max it out for a dyno run, don't want to risk damaging my (stock) injectors.
Will
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, SteadyFast stabilizers, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600, shocks and EZ-Flex suspension, Reese Strait-Line
_Me2_
Fresno, CA
Posted: 08/23/11 08:02pm Link  |  Print  |  Notify Moderator
They list them as not for use on pollution controlled vehicles, etc.
2005 Ford F250 PSD Lariat CCLB 4x4, 6" Fabtech lift on 35s, airbags
2006 Rage'N Falcon 3405
45Ricochet
North Idaho
Posted: 08/24/11 10:21am Link  |  Print  |  Notify Moderator
jauguston wrote:
Rick,
Jim
Oh well, I like to stay within the laws but I'm not giving up the tuner. Sure glad my state don't test. Got to run and remove the mattress tags now
catfishmontana
montana
Posted: 08/24/11 10:51am Link  |  Print  |  Notify Moderator
Exactly.
Civil Penalties
Just saying
Most all say off road/race use only on their websites.
Mine ~ 2011 Ford F350 6.7 SRW, CC/LB, Lariat, Navigation, FX4, 20's, Black with Black Guts.
Hers ~ 2012 Ford F150 Raptor, Blue Flame, Crew Cab, 6.2L
GONE!!! 2010 Chevy Tahoe LTZ 5.3 ~ Most worthless POS ever!
2007 Keystone Montana Mountaineer 30FKD TT
jauguston
Bellingham, WA
Posted: 08/24/11 01:21pm Link  |  Print  |  Notify Moderator
The EPA is out to make criminals out of all of us that just want our vehicles run like the manufacturers intended them to run. The EPA has made diesel engines use more fuel and run with retarded timing that reduces power. How can they convince anyone that burning more fuel is better for the environment. I sure don't buy it. My MP-8 raised my fuel mileage from less than 7 mpg to 8.5 mpg.
Jim
HobbyTalk
NFM
Posted: 08/24/11 01:23pm Link  |  Print  |  Notify Moderator
This was a hot topic on the Duramax forums for a while. Some of the tuners allowed you to do a DPF delete or EGR block without getting error codes. A couple of the larger suppliers have discontined those products even though they stated for off-road/race use only. Rumor was they were pressured by the EPA into doing so.
Just to note, I see nowhere on the Banks web site where it says for off-road/race use only.... but then they don't stop error codes if you do a DPF delete or EGR block.
Sold the RV, bought a house in North Fort Myers
tgif: let's RV - Facebook
mrfishaholic
Olympia, WA
Posted: 08/25/11 04:37pm Link  |  Print  |  Notify Moderator
I use a programmer, makes the engine feel more responsive, smooths accelleration, for the improvement in power and performance, without sacrificing current mileage it is worth it to me. Sometimes I get better mileage but it is sure hard to keep your foot out of it sometimes. It is nice being able to set the cruise control at 65 and not having to care about the grade, mountains, pass or whatever you are towing in...... I love my diesel. I use PPE Race +2 E.T. programmer, I love it.
1996 Ford F350 CC/LB/4x4/SRW (460 Gasser)
07 COUGAR 294RLS Reese HP DUAL CAM, Travel Trailer (TT)
99 Bigfoot 2500 11.6E, 11'6" Truck Camper (TC)
Torklift superhitch, Fastguns & 36" extension, Firestone Airbags
Page of 6
