RV.Net Open Roads Forum: Tech Issues: Problem first time using generator
 > Problem first time using generator
Hawk15
Canada
Posted: 08/20/11 03:30pm Link  |  Print  |  Notify Moderator
Hi, Today I tried using a new Yamaha ef2000is genny for the first time. I Started the genny then plugged the shoreline (30amp) cord into the trailer. Immediately the genny red "overload" light turned on and none of the ac indicators were working in the tt (ie. microwave clock, wall receptacles). I then turned the fridge off and started the genny again, the micro clock came on for a few seconds before it shut-off and the genny overload light turned on again. At the time the batteries were showing 2/3. There was only one led light on in the trailer. I just read in another post that I should turn the main breaker off before plugging the genny into the TT, when I get back to the campsite I'll try this. Is there anything else I should try or do differently? Thanks for any input.
Ps. The TT is a 2010 Tango
#40Fan
Colorado
Posted: 08/20/11 03:34pm Link  |  Print  |  Notify Moderator
Make sure your water heater is turned off too. More than likely the converter is trying to kick in and charge the battery, causing the overload. Have a set of jumper cables? Hook your TV up to your TT battery and then start the generator and plug in the TT cord.
2005 Keystone Outback Sydney 31RQS
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
trucker495
Linden, CA
Posted: 08/20/11 03:35pm Link  |  Print  |  Notify Moderator
Try turning off the elec. to water heater if equipped
robatthelake
Vancouver Island
Posted: 08/20/11 03:37pm Link  |  Print  |  Notify Moderator
Whenever I start My generators I make sure that nothing is turned on.
I also try My darndest to turn everything Off before shutting the Generator Off.
I have No idea why I do this other than having once been yelled at by someone for shutting off a Generator while the A/C was running!
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
Hawk15
Canada
Posted: 08/20/11 03:43pm Link  |  Print  |  Notify Moderator
Thanks for the replies. I thought a 2000w generator would be capable of charging my 2 6v batteries without going into overload protection. My understanding is that when the overload light comes on, the generator continues running but is not producing power. If this is true how will the generator recharge the batteries?
donn0128
Pronounced Ore-gun
Posted: 08/20/11 03:53pm Link  |  Print  |  Notify Moderator
Are you plugging into the GFCI? Mine has a 30 amp plug that only reset by restarting the generator plus it has two 15 amp GFCI protected receptacles. Turn off everything in the trailer that is/could be run on electricity. that includes making sure the refer is on gas only, water heater electric element is off then start the generator. Once it is running, if there is a conserve setting turn it off, once it is at full RPM, plug in and you should be good to go.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
MrWizard
Traveling
Posted: 08/20/11 04:29pm Link  |  Print  |  Notify Moderator
Are you using any kind of adapter like for a 15amp duplex plug to the 30amp RV plug and plugging into one of 15a outlets ?
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
jackandh2o
Golden Valley, Arizona
Hawk15, I have a Kipor 3000 and I have to start it without a load and run it for a few minutes. If I try to use it right away it won't work.
I let it warm up? then turn the a/c fan on for about 30 seconds then hit the a/c. This works good for me.
Ray
DSchmidt_2000
Ventura
Posted: 08/20/11 05:14pm Link  |  Print  |  Notify Moderator
I own a Yamaha EF2000is also. Yes, it has electronic overload protection and when tripped the only way to reset it is to turn off the generator and then restart it.
Something in your trailer is puller more current than the Yamaha is able to provide. As everyone has said, turn off all the power in your trailer, run the generator, and as you turn breakers back on you should find out what is causing the high power draw.
You might want to test just your generator all by itself with a load to verify that the generator is fine. Use something that pulls a lot of power but within the capability of the generator (like a hair dryer or electric heater).
RVnRobin
Can't remember being a
Posted: 08/20/11 05:25pm Link  |  Print  |  Notify Moderator
Your Yamaha EF2000is should be able to power the converter to charge the batteries. In my TT the 45amp converter was origionally on the general receptical circuit. I added a breaker so that the converter is on its own dedicated circuit breaker. I trip all breakers off except the main and the one with the converter. I have a 1000w generator that will charge the batteries just fine.
So much to experience, so little time.
