RV.Net Open Roads Forum: Cummins Fuel Shut off Solenoid - Let's talk!
 > Cummins Fuel Shut off Solenoid - Let's talk!
TominTampa
Bellevue Nebraska
Posted: 08/20/11 05:44pm Link  |  Print  |  Notify Moderator
Gentlemen -
We just wrapped up our vacation trip to Florida with only minor maintenance issues. The first being the loss of the cruise control. Steve at King Cruise was very helpful and will be sending us a new box for the cruise control unit. The second problem was having trouble starting our Cummins 8.3 when it was hot. This came to a head at a service station in Arkansas on the way back when the engine would start and immediately shut down again. After explaining to the attendant that we weren't camping at the diesel pump, we figured out that it was indeed, you guessed it - the fuel shut off solenoid. By turning the ignition key on and prying the solenoid open with a screwdriver we were able to get it started. Another option was to wire it open, but it had enough "magnetism" left to stick open once I jammed it upwards with a screwdriver. Anyway, we managed to screwdrive our way back home and now I'm looking for a new fuel shut off solenoid. Is there one particular brand that everybody is crazy about or seems to have good success with? I saw a product advertised from "Larry B's" which claimed to be an improved solenoid. Can anyone offer any advice either way? Thanks in advance.
- Tom
1996 Monaco Dynasty 36', Cummins C8.3 with Banks Stinger kit, Allison 6 speed.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 08/20/11 05:51pm Link  |  Print  |  Notify Moderator
I carry a spare one (FL70) as this is faily common problem on the 5.9 and 8.3. Sounds like this one lasted 15 years so one more should do you. $ Ebay
04 Monaco Dynasty 42' quad slide
How I tow.
Towing a Prius without a dolly
Where am I?
How I spend the winter.
SCOMP225
Brownsburg,Indiana
Posted: 08/20/11 06:35pm Link  |  Print  |  Notify Moderator
I carry a Spare too. Get the part number off the solenoid and duplicate it.
In a pinch tou can wire tie it, did that on a long trip.
Chuck
1992 American Eagle
wcjeep
Tacoma, Wa
Posted: 08/21/11 12:40am Link  |  Print  |  Notify Moderator
On the 5.9 the shut off solenoid has two separate circuits. The initial start circuit and hold circuit.
Buffalobilly
Holiday Island, AR
Posted: 08/21/11 06:41am Link  |  Print  |  Notify Moderator
Get Bulletin 3887854 Vertical Fuel Shutdown Solenoid Kit for P series fuel pump. Easy fix.
Bill
Buffalobilly
95 Safari Sahara
230 B Cummins
pulling a 2007 Diesel Grand Cherokee
just me
Salt Lake City Utah USA
Posted: 08/21/11 06:47am Link  |  Print  |  Notify Moderator
First off get a RELAY and try this first BEFORE you buy the solenoid. Larry "B" has this to. Talk to him and get his opinion. The relay will go bad first, and is a lot cheaper to replace at a few bucks versus $160.00 for the solenoid.
95 Dodge CC #5 TST plate Flame Red/Silver
not totaly stock
2007 fiver
Tag Ma-haul has been suggested for a name but now The Shoe box
Ivylog
Posted: 08/21/11 07:15am Link  |  Print  |  Notify Moderator
Bbilly, I could not find that bulletin. Mind explaing or giving a link?
Jusr_me, I get the drift of your post but some more info would help.
wny_pat
Western NYS
Posted: 08/21/11 10:30am Link  |  Print  |  Notify Moderator
http://www.fostertruck.com/dodge/ it is right under the picture of the Fuel Solenoid Brackets.
Or you could save a bunch of money and just install a PTO cable to control the fuel shut off, and eliminate the solenoid, and related problems, all together. Should be able to do that for about $50. Many of the old diesels were set up that way. Simple mechanical design.
“All journeys have secret destinations of which the traveler is unaware.”
Jamboree89
Pennsylvania
Posted: 08/21/11 11:39am Link  |  Print  |  Notify Moderator
Tom,
I just went through this on my Dynasty, just replace the solenoid. Its just two bolts, the electrical connection and a pin on the fuel shutoff valve. The most important thing to know is if your bolt spacing on the solenoid mount is 2.5" or 3". Mine was 2.5". I managed to locate a NOS (new old stock) solenoid on e-bay but Larry-B can supply what you need, give him a call and talk to him. Cummins wanted $450.00 for a new one.
1998 Monaco Dynasty
Scion Xb
Collin and Alfie the dogs
TominTampa
Bellevue Nebraska
Posted: 08/21/11 08:52pm Link  |  Print  |  Notify Moderator
Thanks to all for the responses, I'll get to work on this and post the results of the project. Thanks again. - Tom
